Question about SMC Barricade g SMC2804WBR Wireless Router
My computer don't connect the smc modem
Problem connection
  • 611 Answers
Configure properly then you get it
Posted on Dec 13, 2008
I need WIN 7 driver for smc 7003 ez connect usb modem. Can someone please help? Tnx
After navigating to SMC's website, I found the driver for your device, however windows vista/ windows 7 is not listed as supported, however, they did have a driver for
  • Windows 98
  • Windows 98 SE
  • Windows NT4
  • Windows Me
  • Windows 2000 Professional
try using this driver and see if windows 7 will be able to use it.
If you have any questions please let me know!
Thanks,
Mike
May 16, 2010 | SMC : EZ Connect USB Cable Modem...
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
My cable light on my modem goes in and out the internet will connect and then 5-10 minutes later the yellow light will come on on the cable light for about 1-3 minutes then connect again. i have...
Call the cable company to come out for a service call... it sounds like signal issues... could be as simple as a bad splitter or connector.
Dec 31, 2008 | SMC EZ Connect Modem
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Broad band hub
donn't connect the cable driect you use the 5port or 8port swicth then take a cble to modem to that swicth then how many computer you have to connect you can
Driver problem
drivers.myfreewares.com/driverdeveloper-1555-smc-download.html
Sep 25, 2007 | SMC : EZ Connect USB Cable Modem...
Open Questions:
SMC Barricade g SMC2804WBR Wireless Router Logo
102 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
