Question about Kenmore 24032\24036 Top Load Washer
Motor tries to turn agitator,on,off,on,off,on,off
Kenmore elite top loader quite pak two.motor tries to turn agitator,shuts off,then on again cycling on and off ,machine will spin and pump water out ok.problem is in all modes of machine except spin dry..removed agitator and all looks ok,not much to go,sorry...what a great web site!
  • 275 Answers
Decide if you want to take a gamble and replace the timer, or do you decide to replace the washer since it has has problems before, I recommend one minor repair, after that I recommend replacement, cost vs time and warranty.
Posted on Dec 09, 2008
    Genius:
  • 1,199 Answers
Sounds like the belt that makes the barrel of the unit turn is out of line or broken>>>replace!
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
I have a Kenmore Elite Quite pak ll, it will not agitate or spin, motor makes a humming sound.
THERE IS A COUPLING BETWEEN THE MOTOR AND TRANSMISSION SEE IF IT IS BROKE OR WORN PART # IS A 285753A IF NOT THE PROBLEM MOTOR IS BAD. MORE THAN LIKELY ITS THE COUPLING
Apr 28, 2009 | Washing Machines
I have a Kenmore Elite top loader that does not agitate after its filled with water and the lid is shut. I've tried all speeds.
I had the same problem with my Kenmoore and had to replace the agitator...ordered the part through Sears. Wasn't hard to fix, just needed to wait for the shipment.
Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
13 people viewed this question
Sal De
fordexpert
Robert Rankin
