Question about Grip On Tools Grip Heavy Duty Caulking Gun
Iam in the middle of a design project of a caulking gun, rather than jamming what are other problems which are common about caulking guns in general? thanks
  • QASuper May 11, 2010
    If you are looking for things that make caulking a problem, I suggest having the ability to immediately release pressure on the piston. That will reduce dripping.
  • 32 Answers
You can leave them down without releasing the pressure and discover when you return that you have a great big mess to clean up...i hope this helps
Posted on Dec 22, 2008
How do i caulk my bathtub
get caulk and a caulk gun at the local hardware or Walmart. Load the caulk tube into the tray part of the caulk gun, snip the end of the tube. push on the rear of the tube and slowly lay a bead of caulk around the area of the tub needing caulk.
Apr 13, 2017 | Home
Hitachi framing nail gun, fires ok on a large tank shop compressor but on a portable compressor it continually blows air from the piston. The gun has a new o ring kit from a repair shop. They can't find...
the compressor is not putting enough air into the guns cylinder and the escaping air is a safety feature for safety. You need to get a larger comp or increase the pressure coming out of hose. there should be a gauge on comp. Set it for suggested pressure for each separate tool. Be Safe!
My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Jul 22, 2014 | Hitachi NR83AA3 Pneumatic Frame Nail Gun 3...
Cant move caulking gun handle
There should be a thumb release on the shaft at the handle end, press with your thumb and then pull back with the other hand on the shaft. If you have a used tube in the gun, it could be that some of the caulk came out the inside of the tube and hardened so that you cannot pull back the shaft, you will now have to cut the tube off with a utility knife to remove the old dried caulk
Mar 06, 2014 | Draper 43851 Caulking Gun
What's a good caulking gun to buy?
For professional work I use the Ryobi 18 volt gun which is a bit more expensive than your basic gun like a Workforce 60:20 gun.
Jan 10, 2013 | Adhesives, Coatings & Sealants
How do I fix my motor on my Milwaukee glue gun?
not sure if you're talking about a caulking gun or a heat gun, but click this link
http://www.manualslib.com/brand/milwaukee/
and download the manual for your model gun
Jan 30, 2011 | Milwaukee Tool Crafts & Hobbies
How do i use the Stanley caulk gun?
All Caulk gun are used the same way no matter which model you have, hear are the instractions
  • Load a tube of caulk into a caulking gun, making sure it's well seated at both ends
  • Use a utility knife to cut the tip of the spout. Cut off as little as possible, taking into consideration the size of the 'bead' of caulk you need. Some people like to cut the spout at an angle, while others cut it straight; it doesn't make a big difference
  • If using caulk that comes in a cardboard tube, look for a second seal at the base of the spout. Insert a nail or awl through the spout to puncture the seal. Many caulking guns come with such a puncturing device. (Plastic tubes usually don't have a second, inner seal.)
  • If you want more precise instruction then go to the link below
    Read more: How to Use a Caulking Gun ' eHow.com http://www.ehow.com/how_8790_caulking-gun.html#ixzz19CNkzmXG
    Here is also a vid that will show you haw to redey the gun for use.
  • Sep 07, 2010 | Grip On Tools Grip Heavy Duty Caulking Gun
    How do you apply NP1 caulk in a professional way?
    use cauling gun run a nice slow steady bead then use a caulking tool to smooth
    Aug 26, 2009 | Crafts & Hobbies
    The color blue gun has gone milky and I need to replace it. Is this a common problem?
    For a television of this age it is common for the source to deteriorate due to heat.
    Depending on the build and design it could be a blue light gun as in the old projection tv's, or if it is actually an LCD projection then the entire light element will need to be replaced.
    Jun 12, 2009 | Hitachi 53UDX10B 53" Rear Projection...
    Grip On Tools Grip Heavy Duty Caulking Gun Logo
    177 people viewed this question
    Top Grip On Tools Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Grip On Tools Craft and Hobby Expert? Answer questions, earn points and help others
