Question about Dell OptiPlex SX280 PC Desktop
No video and loud beeping sounds
Sx 280 plugged in usb thumb drive and it sparked and now no video and beeping sounds. 1 3 2 it seems in that order.
  • momknows
    momknows Dec 10, 2008
    Thank you Dragon-sun25 and walterb-8, even though it is my son's computer in New York,and I am in Florida, we reseated the memory and i was amazed but it worked. Thanks for both of you setting me in the right direction. I was about to get a hard drive and send it to him and go thru the setup again and I was dreading that. So KUDO's to both of you!!!!!!!
    Dvanwie
  • 107 Answers
Try a different stick of ram if avalible and open the case If i remember there should be 4 lights in there and If i remember that mean memory not reconized or being properly used
Posted on Dec 09, 2008
  • Eric Mitchell
    Eric Mitchell Dec 09, 2008
    Thanks walterb_8 for that link so Yes it is the memory
  • Dell Master
  • 998 Answers
Here’s a link to beep codes for your model SX280: http://support.dell.com/support/edocs/systems/opsx280/en/ug/tools.htm#1285550 Usually beep codes indicate a memory problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
How do i wire up the power source on dell sx 280
This PC requires a special power adapter.
Search EBay for "Dell SX 280 Power".
Dec 16, 2013 | Computers & Internet
Beeping doesn't load
A possible solution will be to reformat the drive. Check if there is any sound coming from the HDD when you plug it in. A whizzing sound means its running, but if there's a cracking/ loud tapping sound, there might be a broken disc in the HDD.
Regards
Mar 06, 2011 | Seagate FreeAgent GoFlex 1 TB USB 20...
Spark plug order installed new plugs and leads but lost the order
For the 2002 Daewoo Lanos:
Includes ALL Models:
S and SX Sedan
S and SE Hatchback
All have the 1.6L DOHC In-Line 4-Cylinder:
Firing Order:
1 - 3 - 4 - 2
Cylinders:
..........(back)..........
|...1....2....3....4...|
.........(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Jul 03, 2010 | 2002 Daewoo Lanos
Cooling fan (902)
in monitor display " Cooling fan (902), problem on the fan, it could be the motherboard detects the fan is not spinning, it could be the fan spins slowly, opening her fan motherboar and check if it needs to change, then the problem is solved
Jun 02, 2010 | HP (219462-001) Cooling Fan
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Hi there, seem to have lost my external harddrive on my desk top, and it is making a beeping sound??
Hard drives don't beep. They make a lot of sounds, but no beeps. If the drive is actually making an unusual noise, it has probably gone bad. Clicking would be a bad disk. Any other noise would be a bad controller board. A good shop may be able to slave your drive to another computer to try and save your data. But don't count on it. By the time a drive makes a loud noise, it's usually gone and unrecoverable.
Before spending a lot of money to recover your data, try the external drive on another computer. Maybe the connection USB port has gone bad on the original computer.
Nov 12, 2009 | Maxtor Hard Drive
Firing Order for Spark Plug Wires for a cavalier v6 93
2.3 and 2.4 has idi ign.syst. mounted directly on top of plugs,2.2 coil pack cylinder numbers are marked on it,from left of elect. connector on coil pack is 2-3-1-4where spark plug wires go,on block, cyl. from drive belt side is 1-2-3-4,timing firing order is1-3-4-2
Mar 15, 2009 | 1998 Chevrolet Cavalier
Daewoo Lanos Ignition Wire Order
spark wire order of daewoo lanos is 1423 with you facing the engine; spark 1 is on th extreme left then 2,3,4 ..insert them as 1 (extreme left) is the highest to be plugged in, under which insert 4 then 2 then 3 at the bottom, hope it helps
Feb 27, 2009 | 1999 Daewoo Lanos
Olympus Fe-280
rotate the knob or pressing to view pictures plug in USB cable sound beep suddenly message appear by click to transfer picture to computer.just follw instrucion.
Jan 04, 2008 | Olympus FE-280 Digital Camera
FE 280 Olympus
I've seen this on some users, did you try a different USB port?
does anything happen when you plug the camera in when it's on? a beep? a window pop up?
Dell OptiPlex SX280 PC Desktop Logo
370 people viewed this question
Alun Cox
