Question about Presto HeatDish Compact Heater
Buzz Sound when plugged in
I turned the unit to off unplugged it moved it from one room to another and now the buzzer sounds when i attempt to increase the temperature.
    Problem Solver:
  • 14 Answers
It may be the level sensor, as if it has tipped over. If it runs first and then the buzzer sounds, it could be that it is overheating due to poor airflow or it is near the supply register while your furnace is on. Hope this helps!
Posted on Dec 10, 2008
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Can i silence the parking brake warning buzzer till i take vehicle to dealer for repair
yes,wont hurt anything,search down by the sound of where the noise of the little bing or buzz sound is coming from and just unplug the harness.
Mar 05, 2013 | 2006 Volkswagen Passat
How can I disconnect the alarm when the drying is finished?
  • Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
  • 2
    Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
  • 3
    Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
  • 4
    Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
  • Feb 17, 2011 | Miele Novotronic T230C Electric Dryer
    Buzz on headphones after PatchMix DSP starts
    Buzz is caused by a bad ground or interference in your shielding check out your cabling or plugs that is where the problem lies.
    Jan 23, 2010 | E-Mu 0404 Sound Card
    NO PICTURE OR SOUND
    The buzz is the power supply attempting to power the set. The click is the unit shutting down. Can you pleae post the make and model as well as whether or not the standby light is blinking? With that info we should be able to give you some options.
    Thanks,
    Dan
    Nov 03, 2009 | RCA Televison & Video
    When I push the start button a buzz sounds and the
    sounds as if the motor is not starting,try to turn tumbler manually.if tumbler turns but motor does'nt start check motor.
    Oct 16, 2009 | Dryers
    Buzzer noise from carrier A/C condencing unit.
    Sounds like the contactor is bad.It has a magnate that pulls in with a call for cooling,It will buzz like crazy sometimes.
    Jul 13, 2009 | Carrier Heating & Cooling
    MK101 won't start
    Can you move the blade with your hand or does the blade not move at all or is the sound buzzing even with the blade spinning cuz mostly this sounds like the blade is stuck and should be able to free it by moving it by hand unplugged all the debris from the tile dust can lock up the blades sometimes if it is not cleaned properly
    Jun 20, 2009 | Mk Diamond Wet Saw with Stand
    End dry horn from dryer
    On this unit, there is no way to disable the buzzer. If you are mechanically apt, you can "follow the sound" of the buzzer and disassemble the area to gain access. Unless it's soldered to a PC Board, you might be able to simply cut the wires to the buzzer (with the unit unplugged of course). I'd cut it in such a fashion that if for any reason you decided to reconnect these wires you would have enough room to strip the mating ends and refasten with a wire nut.
    If you go this route, be sure to cap off all ends of any cut wires. Also know that if this is a new unit, the warantee will most likely be voided out by performing this task. This is a well known complaint about this product.
    Mar 09, 2008 | Frigidaire FLSE72GC
    Changing between the buzz and cd setting for alarm clock
    From the manual (miraculously, I still have it)...
    To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
    If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
    When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
    SNOOZE-BOOST
    To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
    Sep 14, 2007 | Sharper Image SI686 Clock Radio
    Presto HeatDish Compact Heater Logo
    113 people viewed this question
    Top Presto Heating & Cooling Experts
    Mack Baxter
    Starnley Johnwells
    Starnley Johnwells
    Paul Carew
    Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
