Question about Samsung ML 2010 Laser Printer
ML 2010 How do you change the toner in this printer? I can't figure out how to get to it. Tks
    Novelist:
    Champion:
  • 202 Answers
Http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf Section 4 should help you out. Let me know what happens. Good Luck Tim
Posted on Mar 01, 2007
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Oct 26, 2009 | Samsung ML 2010 Laser Printer
Light print problem in sumsung 2010
it is problem your cartridge unite toner powder not support toner supply brush
you change cartridge and buy a new one then solve it
Sep 05, 2009 | Samsung ML 2010 Laser Printer
Ineed samsang ml-2010 original drum
This printer has integrated Laser Toner and Drum.
here is the part: Innovera Laser Toner/Drum for Samsung ML 2010
May 16, 2009 | Samsung ML 2010 Laser Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Laser printer ml 2010, paper pull in problems
I also have the ML-2010R and I also had the paper feed problem. with warnings about paper jam around toner cartridge.
After a bit of reading and people mentioning the big roller that picks up the sheet of paper and that it needs replacement; I decided to carefully try to clean that rubber roller.
I used a brush and medical alcohol to clean the roller. After letting the roller dry I put in some paper and tried to print again and for me it works like a charm!
Jan 19, 2009 | Samsung ML 2010 Laser Printer
SAMSUNG ML-2010
Hello Liz,
I've worked with one of these before, it's really not too bad. Looking at the printer from the front, you can pull on the plastic panel with the SAMSUNG logo from the sides, and it will unsnap and flip down. The toner cartridge has a big handle on it that sticks way out in front. Give it a firm pull, and it should slide right out.
Pay attention to the direction the toner cartridge is in, because you'll push your new cartridge in the same way.
~Cactus
Sep 16, 2008 | Samsung ML 2010 Laser Printer
Fain printing
I'm using remanufactured toner provided with my ML-2010 by Discount City when I purchased the printer and I'm having the same problem.
I have used non OEM toner in other laser printers also with disasterous consequnces so I think you'll have to 'bite the bullet' and purchase a new Samsung toner cartridge unless you can find out who manufactures the cartridge in which case you might be able to souece one directly avoiding the extorionate mark up.
Jun 19, 2008 | Samsung ML 2010 Laser Printer
Stopped printing after I installed new Toner!
If the new toner is original, your unit just burned the fuser. If it is under warranty, any Samsung Authorized Service Center will gladly replace it for free.
Oct 22, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
46 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
