Question about Onkyo TX-DS747
Onkyo TX-DS747 A&B Switching Problem
Hello FixYa Experts,
I have an A&B speaker switching problem with my Onkyo TX-DS747.
It jumps back and forth between the A & B setting. As I have it set to the
A setting there is no audio until it jumps back.
The amp is clean and A & B buttons are clean and have positive positions
when pushed.
The amp will keep the A setting once it is warmed up but as time goes on it
is taking longer to lock onto the A setting.
There are other posts with the same problem on FixYa so I will add my post
to the list and see if the experts can find a Fix.
Thanks much, Edd
  • Anonymous Apr 16, 2009
    A/B Switching.
  • INFO818888 May 15, 2009
    STESSO ED IDENTICO PROBLEMA
ONKYO TX-DS747 SWITCHES FROM A TO B SPEAKERS HOW DO I FIX IT
The problem could only be in the a/b switch, you may need to install a new switch.
Apr 05, 2010 | Onkyo TX-DS747
I need a remote for tx-ds747
You can buy directly from onkyo website, Ebay or Do Google search.
Mar 23, 2010 | Onkyo TX-DS747
Tx-ds747 no display light,when powering on only stand by mode and the volume knob has light ,how to fix it.
Sounds like the "Pure Audio" mode is turned on. This mode is designed to use the amps power to dedicate to audio processing and sound quality. It turns off all front panel lights and video processing. Check you remote or thr front panel of the Onkyo for a "Pure Audio" button.
Nov 23, 2009 | Onkyo TX-DS747
My onkyo tx ds747 is saying protect even if i dont have anything plugged in to it! can you plz help me
Hello
maybe you have defective power transistor output and this is shorted, or the problem is in the power section like shorted diode shorted capacitors or open circuit may cause this, and the STK IC if shorted you got protect warning..
Angel
Thansk...
Aug 02, 2009 | Onkyo TX-DS747
Left speakers are not working on my onkyo tx-ds575
Check the units internal "menu" settings for speakers and audio. beyond that, there would be an internal problem and neded service. Hope this helps
Jul 05, 2009 | Onkyo TX-DS575 Receiver
My unit switches between speakers A, B and neither, while warming up. Lasting anywhere from 5min-15mins until it settles. Then speakers A can be selected and it will stay there. How do I fix this?
I see that I am not only one with same issue with TX-DS747, and would be grateful if someone could post some more info about this problem.
Jul 03, 2009 | Onkyo TX-DS747
Onkyo Receiver swtiching between A and B speakers
Any help on this would be appreciated. I have the same problem now with my 727.
Apr 16, 2009 | Audio Players & Recorders
Speaker switching problem
What the type of switch you have there? its like a push button or a soft button? Often you have a contact switch problem on your unit. I f can access the switch contact and clean it that maybe can help on your problem.
Aug 03, 2007 | Onkyo TX-DS747
Onkyo TX-DS747 Logo
104 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
