Question about Onkyo TX-DS747
Speaker switching problem
Basically mt reciever is switching between A & B speakers like a little kid is playing with the buttons with or without speakers connected, it will turn on "A", turn it off, turn on "B" turn it off and continue thusly until I get frustrated and turn the machine off sound does come out of the speakers for the second their side is on, but otherwise it is the repeated clicking of speaker switching I have a service manual, but am not about to poke around something I cannot see, and for some reason I cannot locate the source Hello FixYa Experts, I have an A&B speaker switching problem with my Onkyo TX-DS747. It jumps back and forth between the A & B setting. As I have it set to the A setting there is no audio until it jumps back. The amp is clean and A & B buttons are clean and have positive positions when pushed. The amp will keep the A setting once it is warmed up but as time goes on it is taking longer to lock onto the A setting. There are other posts with the same problem on FixYa so I will add my post to the list and see if the experts can find a Fix. Thanks much, Edd
    Sergeant:
  • 250 Answers
It can be the circuit got short internally on its tracks so its behaving like this.or also can be because any of its button got internally pressed or stuck up.
just check out.
Posted on Feb 15, 2009
    Genius:
  • 1,199 Answers
Sounds like the relay switch is broken!
Posted on Dec 09, 2008
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
Aug 17, 2015 | Kenwood Audio Players & Recorders
Playing cd's no sound from the speakers when I have the cd/dvd option selected. When I put the reciever on I can hear dead air coming thru the speakers but not when I have the cd switch selected....
You need to find the manual and/or read and understand every indicator and evaluate how it affects the sound. Use a medium volume setting while troubleshooting.Check connections.
Start with the basics. Speaker test ok? FM ok. Digital sources assigned yada yada.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-8060-Receivers-manual/id/480ci254/t/2/
Jun 30, 2011 | Kenwood VR-8060 6.1 Channels Receiver
I have Harmon Kardon AV140 connected to 6 Klipsch speakers. All of sudden I know longer have any sound coming out of my front speakers. Everything was working fine a few days ago. Did we hit a button in...
Only the front speakers failing? All others ok?
There is NO configuration that would have NO front speakers.
Go back to basics, open the manual and use test tones for speaker verification.
Mar 17, 2011 | Harman Kardon AVR 140 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
My last Reciever, I had wireless speakers that worked by plugging into the headphone jack. When the wireless transmiter was plugged into the headphone jack I still had sound coming out of the main...
Your system is designed to interrupt the signal flow once headphones are attached. It can not be changed without internal modifications. There is no control to do this.
Dan
May 12, 2009 | Yamaha HTR-5730 Receiver
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Sound control is via TV remote only
You didnot mention wehther you selected external speakers on you tv. If your TV allows this then do that, first.
Also the sound input to your TV must come from some source, (cable/ Sat). You could remove the audio inputs to your TV and only allow the audio to go to your Receiver.
RCA cables will allow this to be easy just remove the red and white audio to your TV. If you have sent them to your reciever then you must balance the cable box volume (reduce to the lowest level , then raise your recievers vol until satisfied if you are to loud when you switch to a CD then raise TV vol until they match, so your CD doesn't play to loud when switching modes)
If you are using an HDMI cable to your tv than there has to be a setup for turning off the internal speakers on your TV.
Dec 03, 2007 | Onkyo TX-SR605 Receiver
What the type of switch you have there? its like a push button or a soft button? Often you have a contact switch problem on your unit. I f can access the switch contact and clean it that maybe can help on your problem.
Aug 03, 2007 | Onkyo TX-DS747
Onkyo TX-DS747 Logo
57 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Dennis McCollum
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
