Question about Toshiba SDV393 DVD Player/VCR
Temporary Picture Freeze
Playing DVDs has become a problem. Picture/sound will stop momentarily, then restart. There is no rhyme or reason, but it happens regularly on almost all DVDs. It happens with DVDs we've never had problems with as well as new ones. The problem doesn't happen with National Geographic/Nature DVDs. We've tried cleaning the DVDs as well as the player but nothing seems to help.
  • Anonymous May 03, 2009
    I have the same problem and now the DVD stopped all together
Does anybody have advice for recording issues with a Techwood AEDVDRS7?
The dvd disks you're playing.... are they homemade or factory made recordings?
May 13, 2014 | Televison & Video
Stops playing and then says welcome on player
It sounds player get reset for some reason and most possible reason is power supply stops momentarily caused reset dvd player. If you have knowledge about electronics stuff repair then check main/ big capacitor of power supply board and replace it if found leaky to fix the issue or take it in local tv repair shop for that.
Thanks.
Nov 09, 2010 | Sony DVP-NS575P DVD Player
Samsung dvd htx200 region error
no solution but i have exactly the same problem - the system has suddenly stopped playing any dvds at all including ones it has previously played - i get no sound or picture just a circle with a + sign in the middle on the dvd digital display
did you find any solutions elsewhere?
Aug 28, 2009 | Samsung Televison & Video
Unable to get play dvd or get picture on DVD channell on tv
If the player is doing that for all DVDs but playing CDs properly, the player has gone bad due to either the laser and lens being out of whack or the DVD drive just doesn't recognise DVDs anymore and needs repaired or replaced.
Sorry. Best of luck.
Jan 01, 2009 | Philips Televison & Video
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
Problem can you help and dont say contact Microsoft!!!!
overheating can cause problems like that, and 360s are prone to overheating
Oct 12, 2008 | Microsoft Xbox 360 Console
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD images freeze at certain points or playback becomes choppy
sounds like you will need to clean laser, there are cleaners you can buy out of walmart for this. Don't know if they work well, I take mine apart and use soft cloth and alcohol then letting dry, works fine for me.
Dec 16, 2007 | Sony DAV-FR10W System
DVD player freezes
If it's a very cheap unit, it's possibly because the machine can't process the information quickly or efficiently enough, thusly causing the picture to freeze up while the processing catches up with it. Friend has a $30 unit, which happens to constantly.
Nov 07, 2006 | Sanyo DVW-6000 DVD Player/VCR
Toshiba SDV393 DVD Player/VCR Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
