Question about Cozy (W352E) Heater
Blower does not turn on
Cozy wall heater's motor blower does not work
    Problem Solver:
  • 6 Answers
Check to make sure your fan switch is touching the metal.. the fan switch is tiny (size of a dime) with two stake on wire conectors going to it... check to make sure the speed switch (looks like a dimmer switch) is sending power to the fan switch... if all that is a yes then remove fan switch and hold a lighter to the back of it.. should come on in 5 seconds with direct flame.. if you still have nothing replace fan switch..
Posted on Jan 15, 2009
Pilot light is on. Why doesn't thermostat trigger?
You may have a bad heater controller (tells gas to flow and blower to turn on). Only way to find out is to run a tester on it or call a repair man.
Mar 07, 2016 | Cozy Heating & Cooling
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
Need a blower for a cozy wall heater model w2550
model number is WFF81 you can call 502-589-5380 and they will tahe your zip code and give you a list of dealers in your area.
Nov 18, 2010 | Cozy (W352E) Heater
I Have A Cozy Space Heater And It Will Work For Awhile Then Goes Out, Relight The Pilot It Stays On Turn The Heater On And It Will Work Awhile Then It Shuts Off Again
if you have the vent pipe in a chimmney or vented outside wall can cause this problem, need to either put a liner in chimmney or vent insde the room with the heater up thru the ceiling.
Oct 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
Cozy WOW 234 wall direct vent makes loud whistle noise and the two pipes in the heating chambers are hot the third pipe is cold. This is a brand new heater. It throws air but luke warm only
remove the back panel and check the blower for loose screws or debris like sealant tape. and the third pipe is the fresh air intake.
Sep 20, 2010 | Cozy (W352E) Heater
Wires not connected to gas valve need wiring diagram for Cozy wall vent heater
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
Dec 10, 2009 | Cozy (W352E) Heater
Is there an air filter for my ''Cozy'' Counter Flow Wall Furnace
Cozy most generally doesn't provide a place for a filter in its wall furnaces. I have seen people secure a typical house filter to the outside grill where to return air enters. It's cheesy but works.
Mar 15, 2009 | Cozy CFR Utility Heater
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Nov 27, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
238 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
