Question about kawasaki PVS-10921 Portable DVD Player
Charger cherger does not keep a charge
  • 492 Answers
I cannot charge both my dysons. Working perfectly yesterday but not today. I think it maybe the battery charger
The manual for the DC27 can be found here (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc27_uk_manual_alf_120710%20pdf.pdf ) but is not so helpful in deep troubleshooting outside of looking for blockages.
I'm a little confused since you're talking about battery chargers, but this is posting under Dyson DC27/DC28 assemblies, which are both plug into the wall uprights. Are you possibly in the not-quite-right section? If so, reply with your model numbers and that may make things go a bit easier.
In general though, if you have dyson rechargables that both suddenly stop working, the charger is likely the issue. Look at the electrical contacts for both the batteries and the charger, and make sure they are clean (unplug cherger before touching anything, start, if possible, with compressed air to blow lint and such out). Check that the cord for the charger is not damaged, and that your wall outlet hasn't tripped a breaker or a GFI reset.
Good Luck!
Nov 13, 2015 | Dyson DC27 & DC28 Internal Hose Assembly,...
I have my laptop n4030 not charging.
Does the battery need replacing? Did you reboot the machine? Shut down, unplug, remove battery, plug in , reboot. Any change?
Dec 26, 2012 | Dell Computers & Internet
Keep getting message that my battery in low, also laptop goes dead if not connected to cherger.
atteries have a limited life and most need to be replaced every 12 to 24 months. If that amount of time has lapsed since you've replaced the battery, or if damage was done to the battery, such as a spill or overheating, the battery may be dead Unplug the laptop from the wall charger. Remove the battery from the laptop. The battery is located on the underside of the laptop and usually slides out, or can be popped out by sliding the battery release buttons next to the battery.2 Dip a cotton swab in rubbing alcohol. Rub the cotton swab into the battery contacts to remove dirt and dust. Use a cloth dampened with water to wipe dust from the rest of the battery and battery housing unit. If dust is on the connectors, it can block or impede charging. Snap the battery back into place on the laptop.3 Plug the laptop wall charger into the wall. Plug the other end into the laptop. Allow the laptop to charge for 24 hours.4 Disconnect the laptop wall charger from the laptop. Turn the laptop on. If the laptop does not turn on, the battery did not charge, indicating the battery is dead. If the laptop turns on, but the battery lasts for a short period of time, this is a good indication that the battery is damaged or dying.
  • Oct 10, 2011 | Computers & Internet
    For some reason the main phone does not want to charge.
    Hello.
    Your phone may not charge for many reason , here are solution to solve your phone problem .
    Notification
    For how long you have been making use of this phone?
    Is your phone a mobile or a land line phone.
    solutions.
    1. Remove your phone from charging
    2. Check the charger if its still working with another phone if it work it mean that your phone battery is bad or the cherging pot is bad
    3.Then check your phone with another cherger if your phone star to work as normal meaning that your is ok if not ,then you need to chang the battery of your phone your.
    Best of luck.
    Mar 07, 2010 | Lands Phones
    Line down the center of a copy. Tried cleaning
    1.If your toner unite new.
    problem on cherger or laser unite.
    # clean its
    If you are not,may does not supply developer.
    Jan 19, 2010 | Sharp AL 1631 Copier
    When i put cherger its power up other wise nothing happend, pls help me
    Hi!
    Normally this would indicate a problem with the battery or faulty/loose connection with the elements that connect the battery to the rest of the phone.
    When you plug the charger in, the phone will use that as it's source of power & bypass the battery to function. When it's turned on does the battery charging indicator light up at all?
    Try a different battery (some mobile phone shops will have a few spare or at least one compatible to test it out). If that works, you know what your problem is. If that doesn't work, unfortunately it's probably something wrong with the phone's hardware. If it's under warranty, contact Samsung & they can do a repair.
    Hope this helps :)
    Nov 20, 2009 | Samsung SGH-G600 Cellular Phone
    Full of black lines on copyprint
    it is the problem your copier toner or charger. cherger ir dirty clean it then solve your problem
    you install your old cartridge then you quary it
    Jul 20, 2009 | Brother DCP 7010 Multifunction Laser...
    My htc tilt stopped workng.
    I've seen this on the 8525 which is the same basic model (different processor and few different features) as the 8925 (Tilt).
    Most likely it's a bad mini-USB port on the phone. You can check this by replacing the phone's battery with one that is known to be fully charged.
    As for water damage, the only way to know is to check the water damage sticker.
    Dec 12, 2008 | HTC Tilt 8900 Smartphone
    Dual xnav3550
    easy one read opt volt on cherger if o or low replace with same voltag current output local radio shack nice one 15 25$ if u would like info on how to repair charger it self will give info 2 do that just ask normally the transformers burnout it cheaper 2 buy new than rebuild
    Dec 08, 2008 | Dual Electronics XNAV3550 Car GPS Receiver
    kawasaki PVS-10921 Portable DVD Player Logo
    81 people viewed this question
    Top kawasaki Televison & Video Experts
    Henry  Thomas
    Henry Thomas
    wayne chamberlain
    Jaime Hernandez
    Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
