Question about KitchenAid KGST307 Gas Kitchen Range
Kitchenaid Model KGST307HBS5 intermittent will not heat up
Will not heat up or takes 30 + mins to reach 400
also smell gas when the unit is not heating properly
soap tested all lines and no bubbles etc.
Last night took 30 mins to reach 400
this morning worked fine???
Any help would be appreciated..
  • steve_surber Dec 10, 2008
    Would the safety valve also make the unit not heat properly and do you know if this has been an intermittent problem with other
    kitchenaid owners..
    thanks again
  • 171 Answers
The gas leak can be the safety valve. in side the oven where the burner sits on you have to remove the burner to get to it.
Posted on Dec 10, 2008
  • my own stove have the problem with the gas leak on the safety valve, only 2 years old. for the temperature check that the ignitor does not take more than 60 to 70 seconds to light the burner, if that's the problem the oven is trying to maintaining temperature but it can not because the safety valve does not open on time. so the ignitor needs replacing.
Oven heating very slow smell gas
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jul 06, 2010 | KitchenAid KGST307 Gas Kitchen Range
Oven takes too long to reach temp and the smell of gas
Sounds like a weak ignitor is not opening the gasvalve completely. Only testing the amp the ignitor draws will confirm. It could also be a sticking valve. Have a professional verify, this is not safe.
May 10, 2010 | KitchenAid KGST307 Gas Kitchen Range
The oven will not reach desired temperature. Had
it sounds like you have a bad temperature controller thermostat or your temperature sensor inside the oven, (a metal rod attached to a thin metal wire) is not in its proper place. It clips into connectors located at the back center of the oven itself.
Mar 14, 2010 | KitchenAid Superba KSRG25FK Side by Side...
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Kitchenaid KGRT507FWHO gas range not firing or not getting hot
your ignitor is either cracked or bad
gotto sears type in your modle numbber and look for ignitor in parts search reletivley easy repair
Oct 07, 2009 | KitchenAid Cooktops
KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Aug 29, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Gas oven not heating
I'm guessing that there is an issue of some kind with flow of heat inside the oven. Gas ovens use the hot air/gas exhaust to heat up the oven. Flames mean heat. The flames should be about half an inch long or so. If not, there may be an issue, but I don't think that is it.
Have you lined the oven with foil? It is possible that vents from the boiler section are closed up? That will prevent heat from reaching the oven.
Dec 03, 2007 | Whirlpool SF367 Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
314 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
