Question about Troy MIG100 90-Amp. Wire Feed Welder
Mig welder tripping power supply
I have just bought a used 185 amp boc mig welder and its tripping a 32 amp supply what could be the problem
  • 3 Answers
The breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
MyCH115v flux core welder will not feed (wheel will not run)nor will it arc.What should I look for to be the problem?
Look at the power supply feeding the unit. Has the breaker tripped? Turn the breaker off to the outlet supplying the welder and then turn ot to the, "on" position. You can't reset the breaker from the tripped position. You need to turn it, "off" first. Look at the connectors to make sure they're plugged in properly. Check to see if there is an internal breaker that might have tripped.
Dec 06, 2014 | Welding Tools
Need manual for Air products mig 185
I believe Air Products was bought by Miller. It was a long time ago and they have not put anything on their web site to support owners of AP weld equipment. Contact a local Miller sales and supplies store to see if you can get more information.
Aug 25, 2014 | Welding Tools
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
My welder only welds for about 2 seconds then trips house breaker. i have a good dedicated 20amp breaker for the welder. what could cause this? the welder breaker in back of machine does not trip.
Is enough for this machine, but probably is not a fuse dedicate it just for this end side.
If you can turn all lights off and other items that might be in use with the fuse. If you can't then upgrade the fuse to a 30amp.
Jan 10, 2011 | Miller MilWeld MLL907263 /AutoArc XLT142...
Hobart 140 voltage drop when welding in all setting using 30 wire and uni mix gas will start out welding good then will not ?????
Check your input line voltage. 115 volt Mig welders / plasma cutters need stable voltage / current. Test to see if the voltage drops to below 100 volts when welding. If so, find a more stable power supply.
Mar 05, 2010 | Hobart Welders 500505 Handler 140 MIG &...
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
Troy MIG100 90-Amp. Wire Feed Welder Logo
592 people viewed this question
Top Troy Welding Tools Experts
Bill Boyd
Are you a Troy Welding Tool Expert? Answer questions, earn points and help others
