Question about Dyna-Glo (PPH16-LP) Utility Heater
Kerosene heater won't restart
A dyno-Glo 125,000 btu kerosene heater with a thermostat, will run for a while, shut off, and display E 1 error code. I don't have the manual and don't know what this is. If the switch is turned off and on it will turn back on, but won't restart automatically.
  • bjmac333 Dec 17, 2008
    I have the same problem. The fan turns on but the fuel won't ignite. Then E1 displays on the read-out. The igniter is functioning with plenty of spark.
  • smithstonesu Dec 23, 2008
    My heater will not keep running. Please help!
I had the same problem! check the two lines on them take them off and make sure that they have no cracks if they do you can get them at any hardware store bring in the lines and match them up! then check the psi gauge make sure there is preassure if there is not take off the back plastic piece behind the fan! there will be a gasket i cleaned it up put some silicone on it, then i put the gasket back on and put some silicone on top of that. i secured it let it dry for about 30 mins. Then i turned it on and there was pressure but still did not ignite. There was an adustment screw right next to the psi gauge i adjusted a little and it runs fine now!
Posted on Dec 19, 2008
    Genius:
  • 1,199 Answers
Replace the thermastat!
Posted on Dec 09, 2008
2 Suggested Answers
SOURCE: Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Posted on Jan 14, 2011
Hi i have a dyno glo pro heater model number RMC-KFA170TDGP it worked great last year this year its been nothing but a pain flames shoot out the front by times sounds like its getting to much air but the...
did you try cleaning the lens of the photocell, they git dirty from smoke ver time which regulates the flame or replace the nozzle, sounds like it could be getting plugged up? usually any heating store would have a nozzle for a couple bucks if you get the number off it. the nozzle is right where it comes out and they are common to plug up at times with wear
Jan 18, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Keep getting E1 error code, where is the fuel pump located? where is the fuel filter located on my dyna glo deluxe multi feul 170000 btu heater
The fuel pump is directly behind the fan motor as the fan motor runs both. The fuel filter is under the electrical control panel on the side of the heater usually has four to six 5/16 head sheet metal screws that hold it on. Remove the screws and then the cover comes off and this is where you will find the fuel filter.
Dec 21, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
The unit won't run with cover on. Fan stsrts and
Its not getting enough air to burn with the cover on. See if you can figure out how to adjust the air flow.
May 02, 2010 | Reddy HEATER RH125T 125,000-BTU...
I have a dyno glo work horse kerosene heater modle rmckfa65-wh I TURN ON HEATER BUT IT WILL ONLY STAY RUNNING FOR 5 TO 6 SECONDS.WHAT DO I NEED TO DO TO KEEP IT RUNNING?
If it is a gas,thermo type heater,then the thermocouple is bad.Check and make sure the pilot lite flame is touching the tip of the thermocouple,if it is not,adjust it,to where it will.If it is not adjustable,replace the thermocouple.
Jan 15, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Surges then a big puff of smoke and it shuts down
Jan 02, 2010 | Reddy Heater-30-55,000 BTU Variable
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Kerosene heaters run for 30 mins then shuts off.
Sounds like the pump or air filter is dirty. If cleaning them doesn't help, the pump will need to be rebuilt.
Oct 14, 2009 | Reddy Heater 60,000 BTU Kerosene...
Dyna-Glo (PPH16-LP) Utility Heater Logo
472 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
