Question about Lexmark X4250 All-In-One InkJet Printer
I have an error #1200 on my fax machine it won't clear
  • 117 Answers
Methylated spirits on the cloth , turn machine off, and open the cover as you would do it when replacing cartridge.
make sure machine is turned off so cartridge will not move to center.
clean the chrome metal bar inside machine with the methylated spirits - move the cartridge to the other side of printer manually. and clean the same bar that the cartridge was sitting on.
this should fix the problem.
Posted on Dec 09, 2008
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
You can check this article on how to solve that problem:
Nov 11, 2012 | Lexmark F4270 Plain Paper Inkjet Fax
When I start machine C451 it says Call Tech Error C-B003
FAX Board Error To clear turn power off and on the machine if it comes back fax board needs replacement and or main board. Check your phone line is it clear use a old phone and listen to dial tone and have some one call the fax line listen to line clear and crisp? Phone company check line also. Nice machine!
Mar 05, 2010 | Office Equipment & Supplies
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Clearing memory Brother 8360p
Press quickly......MENU 2864 then press 91
Oct 16, 2008 | Brother FAX-8360P Plain Paper Laser
can i have a solution to this problem? thanks!!!!!!!!!!
Nov 26, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Line error
I have a Sharp UX-300. When I get a line error, the easiest way to clear it is to unplug the fax machine from the power outlet and let it stand for at least a minute. Then plug it back in to the power outlet. If this does not clear the problem, use a regular phone to check if the phone line between the fax machine and the wall is 'OK'.
Nov 15, 2007 | Sharp UX 355L Plain Paper Thermal transfer...
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Lexmark X4250 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
