Compass and fuel millage gauge works then quits.
Test the gauge compass +full , for open , corrosion, wires. 2) resistor open normall by 10 ohms 3) maybe can use the thermistor test for open or defective 3) test for open fuse or bad contact fuse, dirty or corrosion or loose wiring.
you can go for download the diagram to www.autoelectronico.com this web is spanish however you can translate. I strong recomend you by powerful information update+links DOWNLOad free in PDF format. try it and fix it.
God bless you
SOURCE: fuel gauge
The fuel tank has 2 different fuel level senders(floats) It needs both of them. You have to drop the tank, and pull the pumps.
SOURCE: 2002 mercury cougar fuel gauge
Comeing from a cougar expert seeing how I own three mercury dealerships called Holcomb, Holcomb, and Holcomb's if anyone should know the answer to this one it is certainly me. I do all the buying, selling, mechanics myself. Last time I had to fix this for someone I took a mental note. First you are going to have to look on the outside of the vehicle behind the drivers door. This is called a quarter panel but for you lamens it is the fender. You need to look for a round cutout in the rear quarter panel aka Fender. If you will take notice it has a small petrustion that looks like you could stick your finger in it. You will need to pull this hatch open once inside the hatch you will notice another security devise for keeping the full locked in safe. This is a gas cap which leads to a filler neck. You will need to insert gas through this feature and that should take cared of that problem. I am glad I could be of some service if you have any other questions please contact me at one of my many dealerships my number is 501-760-2300 and ask for the main man. David You have been a great pupil and I would love to teach you some more. Thanks
SOURCE: 1993 Jeep Grand Cherokee Fuel Gauge not working
There could be two problems here:
1. That buoy floating tank is not working properly
2. That the electrical system that fails to submit the dashboard.
Review this information:
- ZJ-Secc-8E-Instrument-Cluster-and-Gauges
Page 2 - Fuel Gauges description
Page 4 - Voltimeter/Tachometer/Fuel Gauge/Low Fuel Inoperative
Page 10 - Specifications
- ZJ-Secc-14-Fuel-System
About Fuel Tank components
- ZJ-Secc-8W-Wiring-Diagrams
Fuel Tank and Gauge & Sensor Units Sending (Page 93 and next)
Good luck... and remember rated this help.
SOURCE: over head outside temperature gauge and compass has quit.
The overhead console is quite prone to internal failure. Dim, intermittent, or dead displays are a common symptom of an internal failure. We offer a reasonable repair service with a lifetime guarantee. Check it out: www.autoclockrepair.com
SOURCE: the overhead compass/temp gauge is
If the overhead lights are working but the console is not then it is a bad console. I offer a repair service in which I replace all of the faulty electronic components, and it includes a lifetime warranty. I have a bunch of tech info there; how to remove the console, etc. Check it out and drop me a note if you have any questions, thanks! www.autoclockrepair.com
