Question about Microsoft Xbox 360 Console
Xbox 360 error 73
Well i was plaing my 360 1 afternoon and it was working fine but the next day i turned it on and it started fleshing one red light and error 73 showed up at the screen and it has been a week since iv been able to play my 360 please teach me how to fix it and soon
  • 4 more comments
  • light0beast Jan 06, 2009
    I get that problem also. It occurs after I play DMC4 and turn it off to watch TV and let it cool for about two hours.
    When I turn it on, the damn console give me E73... what should I do?
  • lghtnsxy Jan 25, 2009
    i also have this problem. i tried covering the system with blankets while it was on for 20min. then i noticed 2 blinking red lights, turned my system off then on again- it worked but only for 2 hrs and then the error message came again.
  • Anonymous Jan 26, 2009
    ive got it too, cant fix it. goodluck tho,
  • Anonymous Mar 29, 2009
    i was palying it and the screen froze so i turned it off and when i turned it back on one red ring showed and says error e 73
  • sh4wn5qu4r3d Apr 03, 2009
    was playing halo went to turn off the console real quick and then the screen went black saying error e73 contact xbox support or what ever
  • Anonymous Apr 22, 2009
    i called the xbox company and they said to send it back to microsoft so i will
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Posted on Jan 01, 2009
    Problem Solver:
  • 11 Answers
Error code 73 is a general hardware error - ethernet port.
Here is a link to a web site that I have found fairly informative. http://www.xbox360-hacks.com/forums/viewtopic.php?id=2099
Posted on Dec 10, 2008
On may 2, 2009 i turned my xbox on to see the one red ring. I searched and searched until i just decided to do the towel trick. And it worked. NO MORE RED LIGHT!!! I kept 3 towels wrapped around for twenty minutes and then let it cool down. After 20 minutes i was back to playing GTA 4
Posted on May 04, 2009
If you get this error the perment way to fix it is ''the x clamp replacement" ......look it up on you tune
Posted on Apr 23, 2009
    Scholar:
  • 68 Answers
Www.rapelectronicsgroup.com
a true fix requires solder removal and replacement from my free to let it on the gpu, etc
Posted on Jan 09, 2012
Dont send your xbox in just jam the fans in the back with tooth picks pr something that will fit and let the xbox over heat then unplug the xbox from the back then plug back in and wait a minute then turn on again. if it stays red after you do this then just re do it. your xbox would be fix for a little bit and when it goes red again do it again
Posted on Dec 05, 2010
It has red light on the front and the screen says error 73
here is a webpage with some tips http://www.360errorcodes.com/xbox-360-error-73
also i you want to get it repaired go to craigslist.com and search up xbox repair
Jul 28, 2011 | Microsoft Xbox 360 Console
Hello my problem is in xbox 360 elite e 73 one light red
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 28, 2011 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Sep 06, 2010 | Microsoft Xbox 360 Pro System Console
Three rings are green one red on tv says error e73
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Thank you
Jun 04, 2010 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Apr 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
I have one red light on my xbox 360 elite with code E 73
https://www.yousendit.com/download/THE2b3BORkUrV3lGa1E9PQ.
hope this helps its two ebooks on how to repair red light error ,full instution plus pics show u how.this download is only there for 7 days or 100 downloads.DT
Feb 23, 2010 | Microsoft Xbox 360 Elite Console - Black
3 red flashing lights on xbox360
General Hardware Failure
usually caused by the E-73 Error from defective X-Clamps/Heatsinks
Feb 07, 2010 | Microsoft Premium System for Xbox 360
Microsoft Xbox 360 Console Logo
18,231 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
