Question about Canon imageRUNNER 5000 Copier
Canon Imagerunner - Priority??
How can we set a priority on the Imagerunner 5055 so that people making copies have priority over people sending print jobs without having the set the "Interrupt" ....cuz the lawyers don't want to have to set the interrupt button on the copier everytime they make copies.
  • 168 Answers
Touch add functions key then touch common settings then look for key that says priority
Posted on Dec 09, 2008
Fixing problem
If you mean the toner can be brushed away easily then you need a new fuser wire. This wire gets hot and fuses the powder to the paper.
Jan 14, 2014 | Canon Imagerunner 5055 Digital Copier
How do i send a fax?
Hi kimberley299,
To send fax using your Canon Pixma MX340 follow the steps below:
1. First, you need to hook up a phone line from the wall jack to the lower phone jack on the back of the PIXMA.
2. Now go into the menu and set your PIXMA to telephone priority mode (manual fax recieve), fax priority mode (auto fax receive) or distinctive (fax) ring/auto answer mode.
3. To send faxes, put your originals in the feeder or on the glass, select fax mode, enter the phone number, and press start.
Hope this helps.
Thank you for using FixYa.
May 09, 2011 | Canon PIXMA MX340 Wireless Office...
My epson printer delays while printing job is sent to it.
Apart form changing the Advance Settings from the Printer Properties (i.e. Print directly to the Printer) we can change the Priority of the Print Spooler to make the Printer working fast from the Computer.
The “Priority” of a task is the degree of urgency that the task presents to the Processor- Request from a task with higher Priority are served earlier.
Now the default setting for Print Spooler is to run at Normal Priority. Now if the Customer mostly use his Printer for printing form Computer, we can make the Print Job faster by change the Priority.
Here is the Solution Below:
1. Open up the Registry Editor
2. Navigate to :
HKEY_LOCAL_MACHINE/ System/ CurrentControlSet/ Control/ Print
3. Right Click on the Print folder and create a new DWORD value called “SpoolerPriority” and set it according to what value you want or if it exists, just
set the value.
The value are as follows:
OxFFFFFFFF for IDLE Priority
0 for Normal Priority
1 for High Priority
Sep 13, 2009 | Office Equipment & Supplies
Slow printing as if memory is full. Prints a little at a time, takes 4min for one page. Restarted and reset defaults.
2. Navigate to :
set the value.
1 for High Priority
Aug 11, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Minolta Dialta Di 350f how do you change the display language
1. User's Choice Function Setting Procedure
<Procedure>
1. Press the Utility key.
2. Touch the “User’s Choice” key.
3. Select the appropriate screen from the menu.
4. Select the appropriate function.
5. After the settings are complete, touch the “Enter” key to validate the settings.
2. User's Choice Function Tree
Memory Recall
User’s Choice 1/6 Mixed Original Detection
Language Selected **************** SEE THIS ONE
Original Copy Default
Auto Paper/Auto Size
User’s Choice 2/6 Drawer Priority
Special Paper
Multiple-in-1 and Booklet Copy
Zoom
Auto Panel Reset
Energy Save Mode
User’s Choice Mode User’s Choice 3/6 Plug-In Counter,ID Key Reset
Auto Power Off
LCD Back-light Off
4in1 Copy Order
Density Priority
User’s Choice 4/6 Default Copy Output Levels
Priority Density
Output Priority
Intelligent Sorting
Output Tray
User’s Choice 5/6 “Small” Originals
Scanner Dry
User’s Choice 6/6 Density (ADF only)
May 26, 2009 | Konica Minolta Office Equipment & Supplies
Scan 5 separate documents into 1 e-mail instead of 5 e-mail
I'm assuming you have pressed SEND button at top.
There is a DIVIDE INTO PAGES button towards the bottom right, if it's a blue colour press it to make it grey, this will send the docs as one file.
Mar 26, 2009 | Canon imageRUNNER 5000 Copier
Installing staples in a Canon imagerunner 5055
Open the finisher door and you will find the place, it is in the front side. Regards
Feb 20, 2009 | Canon imageRUNNER 5000 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
145 people viewed this question
old marine
old marine
Corne Viljoen
