Question about Hotpoint Washing Machines
Waters going through GASKET FLOOD HEAD, on Extra Large Load!!!
I have a HotPoint Mod: vbxr1070w0ww. Water is coming out of the GASKET FLOOD HEAD and attached pipe when the washer is agitating. This only happens when washing Ex-Large loads. I have been washing ex-large loads for a long time now in this machine but this problem is recent. Could the problem be with the GASKET FLOOD HEAD or the Water Level Pressure Switch or could the problem lay in the part near the base of the tub that the Water Level pressure switch is connected to. Also I don't beleive that the pressure hose is damaged. I looked at it last night but i can check it again if necessary. Thanks for the help.
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Posted on Oct 16, 2008
SOURCE: I have a GE Model WHDRR418GOWW washing machine. On
In the GE washer motor there is a chip /WHDRR418GOWW . If just the chip is bad will the motor need to be replaced
Posted on Jul 20, 2009
SOURCE: simpson enduro 751 clothes washing machine
Befit Sports are the suppliers for motocross gear, enduro clothing, ATV apparel, dirt-bike clothes and moto gloves.
Visit our web site http://www.befitsports.biz
or
contact us at info@befitsports.biz
Posted on Sep 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: when i have a large or ex large load there is
the tub seal has likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 2468 Answers
SOURCE: My kenmore washing machine mod.
the pressure switch underneath the control panel is bad it is a pressure switch and will have a plastic hose connected to it along with some wires
Posted on May 22, 2011
Just keeps filling at the start of program and displays H20
Your washer has a bad water valve or fill censor telling machine need more water then to much water sends a flood warning shuts down so will not flood your home look for small clear tube coming from tub to a type control hose may just came off
Mar 09, 2015 | Hotpoint Ultima WF860 Front Load Washer
The water heater on my hotpoint aquarius wd440 1400 spin washer drier came out causing water to flood out my kitchen i have knocked it back in but it came back out again should there be some sort of a clip...
I trust this is the water heater you are referring to...There is a large nut 10mm in the centre of it this has to be tight,this in turn will Expand the rubber water seal and in effect stop any leaks...God luck
Feb 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Can sumet be blocked in my washer as wen it spins the water dont empty and i get a flood out the door and powder part
You need to clean the filter.
Remove lower rear panel of washer, locate and remove large black hose on bottom of drum.
Remove and clean plastic filter inside the hose.
Jan 22, 2011 | Hotpoint WMA40 Front Load Washer
Blowing white smoke after warming up
It sounds like you have a weak head gasket.The antifreeze is mixing in the combustion chamber.The heat expands the gasket that is why for now it only does this when the car is hot:)
Sep 27, 2009 | 1998 Cadillac DeVille
Will not pump out
Remove lower rear panel of washer. Lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
Locate, and remove large black hose on bottom of tub. Remove plastic filter inside, and clean. Check pump also. Refit filter and hose.
Plz rate if helped.
Apr 04, 2009 | Hotpoint Aquarius WD640 Front Load...
F 18
Plz rate if helped.
Mar 25, 2009 | Hotpoint Aquarius WD640 Front Load...
Machine wont go into spin cycle
The pump fiter is probably blocked.
Should now be o/k.
Before you do anything, lay the drain hose down into a bucket or bowl, and drain all the water out, so you do not have a flood when you remove the hose.
please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aqualtis smells awful. the smell is coming from the drum. we have taken the pump off and although this smelled it was nowere near as bad as what is coming from the drum.
run a large load with no clothes and no soap. use hot water and a full gallon or more of bleach. do an extra rinse to make sure all the bleach is rinsed out before putting clothes in it again.
Jun 28, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WD440: IT seem when it supposed to pump the dirty water out,the waters are not coming,but if i take the pump and put down on the floor ,the water are coming out and it run the whole spin...
If you are getting voltagae to the pump and the water is not pumping out then you have a bad pump, just replace it and you have the problem solved, If you do not have voltage then we would have to find out why.
May 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
171 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
