Question about LG 24 in. LDS 5811 Built-in Dishwasher
E1 error on LG dishwasher
I have checked the inlet water valve and water is not making it pass the main valve. Will replacing the water inlet valve fix the problem or is it usually something else?
  • Chaz G
    Chaz G Dec 10, 2008
    Take a good voltmeter and check resistance using Ohms. The measurement should be between 800 1200ohms. Mine showed infinity meaning its crapped out.
  • Chaz G
    Chaz G Dec 11, 2008
    YEs inlet valve is bad, replaced and now recieving e1 error code. I believe b/c the motor is spinning up too fast.
    do you know the part number to replace the motor for this unit? Would i need to replace the impeller too or just get the whole assembly?
    Scholar:
  • 110 Answers
As per my email reply chazmano5, the problem is likely to be the water pump/motor assy.
They have a very common fault of the impeller breaking on the motor shaft. The motor still spins, but the impeller doesn't, so there is no water being pumped.
The machine senses there is no water pressure and shuts down, displaying E1 (eg: it thinks no water pressure means there must be a water leak) Unfortunately the motor/impeller is only available as a complete assembly.
Posted on Dec 11, 2008
We keep getting an error message E1. We have an LG 2120 model
The E1 or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Dec 13, 2014 | LG Dishwashers
HOW TO CLEAR CODE E1 ON LG DISHWASHER ?
The 1E error or fault code is to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Jun 13, 2014 | LG LDF7561ST FulIntegrated Dishwasher with...
E1 error on Baumatic BAD6003
If you are getting E1 error then the dishwasher is suggesting that water is getting in but not enough. But if you are getting no water into the dishwasher then the water inlet valve inside it is faulty. Have you checked if there is water inside the dishwasher when you get E1 error. Another thing to find out is the water pressure specification of dishwasher and whether it is consistent with the mains pressure in the house. Usually there should be a plate on dishwasher door which would give water pressure required.
Apr 20, 2014 | Baumatic Dishwashers
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
Hi, i have an LG dishwasher and am getting an e1 error ... it seems to go through the first wash ok, the soap gets used, the water drains away, but then thats it, ding ding ding...ive cleared the bottom,...
e1 error is failed wash motor it sounds like when it goes to do the second wash its overloading the only other thing it could be is the the inlet valve check to see if the water is coming in before it dies. p.s. as a former service agent for lg the general procedure when we get to an e1 error we just order a wash motor for it & replace it & 90% of the time it works but the other 10% is cocroaches got to the computer or the pump or the inlet valve are faulty & are causing it to overload.
Jan 14, 2011 | Dishwashers
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 3 in 1 Dishwasher model LD2131SH
E1=Water inlet Error
Causes:
(below 10 psi)
Inlet Valve is OK?
by impure water.
Solutions:
device.
by the Test Mode.
Replace the Air Braker.
Aug 14, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
839 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
