Question about RCA D52W19 52" Rear Projection Television
Blue outline on all images
I have cleaned the screen,mirror,bulbs. Did not help.
  • 1,199 Answers
The blue lens needs to be adjusted from the inside of unit!
Posted on Dec 09, 2008
Do I need to clean the screen on a DLP television? I have only changed the bulb. I feel like the picture is getting less sharp.
Not the screen so much as the projection mirror which is located on the rear wall of the Set. If the mirror gets dull it can make the picture dim and dull looking. Cleaning the mirror will help. Some models have a small mirror which projects the image back onto the rear mirror. Dont use windex, just a damp cloth then dry good.
Jul 21, 2011 | LG Televison & Video
All areas that should project white are yellow could this mean bulb is getting old or maybe the settings of the compoter its hooked upto need to be chnaged please advise
If the screen is getting more yellow, that is due to either an old bulb, not producing so much high frequency light, or the blue LCD imager is dirty/burnt or the mirrors require specialist cleaning.
Cleaning the LCD units and mirrors takes about 2 hours to complete including re converging.
Hope that gives you an idea.
Dec 31, 2010 | InFocus Proxima UltraLight LS2 Multimedia...
How do i clean the bulbs and mirrows in a hitchi 42v710
The bulb is not an imaging element meaning dust on the bulb will not effect image quality and thus recommend not messing with it. You will need to remove the covers and use a very soft cloth to clean mirror. These products us a "first" surface mirror and scratch or imperfection or cleaning swirl on the mirror will show up on projected image. Suggest his be left to a professional. good luck
Jul 05, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Mitsu 65" DLP-picture seems washed out
Most likely cause of your trouble is dust on the small mirror inside you set. Your DLP set has 2 mirrors not including the DLP chip itself which has about 500,000 tiny mirrors. The 2 mirrors reflect the DLP chip image to the screen you view. The first is the main suspect it's about 4inches by 7inches. It's mounted on the bottom center facing backwards. This mirror faces slightly up and somtimes after time dust, smoke, dirt settles on it . The second fills the space of the entire back of the cabinet but it faces down and takes alot longer to get dirty.
The compartment is sealed but dust seems to find it's way in. If you remove the screws that secure the screen assembly from the top , sides and bottom. Make sure to have a friend available the screen assembly is delicate when it's not mounted to the cabinet. You can remove and clean the mirrors. These mirrors are glass and you can use glass cleaned. Don't use glass cleaner on the screen it's plastic. You can clean it if necessary with plastic cleaner only. Probably not needed.
Good luck.
Apr 23, 2009 | Mitsubishi Televison & Video
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Actually, we didn't remove any bulbs, we removed the lamp in the back of the tv.
Dec 14, 2008 | RCA HD52W59 HDTV Projection Television
Toshiba TDP D2 Projector
A mirror got loose in the opening from where the bulb sends the light to the "panel" It is blocking part of the light.
I'm not talking about one of the tiny mirrors that makes up the DLP, but there is silver box where the bulb light initially goes. the walls are lined with mirrors whose adhesive fails when exposed to great heat.
I can easily fix it, as i have fixed many of them from this problem.
Dec 10, 2007 | Toshiba TDP D2 Multimedia Projector
Yellow/blue outlined image while viewing
reset the settings to factory default. the resolution and phase is off. also make sure the projector is not too close to the screen.
Nov 29, 2007 | InFocus LP 735 Multimedia Projector
Cleaning lenses and mirrors on dlp
I have found a way to clean these, the mirror is very sensitive and doesn't have a glass coating like a regular mirror and if you touch it with your hand (or in my case my forehead) even the tiniest speck of oil will distort the picture but without touching the mirror you can use a new swifter duster, any sort of cloth or tissue will leave lint. So I dusted the mirror first in case any dust fell then I cleaned the lens and blew them both off gently with air and it works great.
Sep 17, 2007 | Televison & Video
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
