Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
Top shelf not cleaning
I have a brand new (Dec 1st 2006) Kitchen Aide KUDP02CRBL2 and the glasses on top shelf are not getting clean. Center arm is free but turns very very slowly. Sears repairman checked all tubing and jet holes and all were wide open. We then tried to catch the center arm rotating by yanking open the door while running but we could not discern any rotation; however the arm might have moved about 45 degrees in 30 seconds. Repairman then told me that that is how it was designed. I don't believe him. If I yank the door open really fast while the dishwasher is running I might catch the middle arm moving about an inch or two before it stops. I think I should see it move at least 90 to 180 degrees before it stops with at least some water spewing out. Do I have a case for getting a new pump? or repair/replacement of unit?
  • Ken Petrones Feb 28, 2007
    Repairman did not check the screen. I called Sears after posting to this website and they told me that the center arm should rotate about once every 5 seconds (seems slow). They are sending another repairman out to further check. I think the pump is faulty since the unit is so new but I'll have him check the chopper screen. We usually rinse solids off before washing so I'm not hopeful.
    Thanks so much for your reply,
    Ken
  • fastone0 Apr 08, 2009
    Im having a very similar problem, i have verified that nothing is clogged, but i have not checked the chopper screen, im not seeing one on my model (KUDK02CRBL1). The washer is barely a year old. Did you find there to be a problem with the pump?
    President:
  • 878 Answers
Kenp, did the repairman check the screen where the chopper is located? If this screen becomes clogged with gunk, water will be restricted going to the center arm and you will either have slow or no roatation. He would of had to remove the lower spray arm, filter and accumulator assy. to get to this. I had one the other day with the exact same problem and the chopper screen was plugged completely. If your dishwasher is not working right, you have 1 year warranty, parts and labor. You have a case for them to come back. Catriver...post back
Posted on Feb 28, 2007
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 13, 2014 | GE Dishwashers
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Top rack - glasses etc... not getting clean - bottom rack and utensils seem fine?
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 02, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Items in top shelf do not clean fully.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
sytrswgh
Jul 05, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Top row doesn's come clean
Dishwasher
How to Buy
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 16, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Dishes on top shelf, usually cups and glasses, not washing correctly. Have tried rinsing cl eanser to no avail
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results. Might also be worth checking the other 2 spray arms at the same time.
Jan 25, 2010 | Belling 24 in. IDW602 Built-in Dishwasher
My Kitchen aide dishwasher doesn't seem to be spraying water during a cycle. It fills with water but that seems to be all. also is there some where that I can go to get a trouble shooting manual
the chopper sceen gets pluged and wont pump good.it's kinda ticky to get to you will need #15 torx bit to remove grab center of the spray arm and twist til arm will lift out, the tube going from center to back twists clockwise careful not to break it, take all the screws out of cover and take it out. in the sump tward front left down in bottom is 1 more screw if you have a wet vac or turkey baster to get water out to see it. it holds down a half round lift straight up you will see the screen clean it out and put everthing back
Dec 28, 2009 | KitchenAid Architect? II K SERIES KUDK03IT...
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
GE dishwasher Quiet Pro 3 middle washing arm
Try unscrewing it from the bottom, remove it and give it a clean. If it is full of food it will not turn.
Check the funnel on top of the basket is free of food too.
Jun 10, 2008 | Dishwashers
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
282 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
