Question about Brother LS-1217 Mechanical Sewing Machine
Have tried to sew with my brother sewing machine and looking at
The finished job I can see the bottom thread loops from the top. How can I adjust my machine so that this stop happening?
  • 2 more comments
  • connie7457 Dec 22, 2008
    Guru,
    I did what you said could be the problem. I cleaned it completely, and adjusted the bobbin tension. It did help some. Then I noticed that the top thread was looping and showing on the bottom of the material. I put the top tension on 6 and that didn't help. Unfortunately, with Christmas crazy stuff happening, I haven't been able to get back to you. What would you sugest that I should try next?
    Thanks,
    Connie
    Guru,
    Thank you for your input. I will try flossing the top tension, as soon as I get a chance. You have a Merry Christmas. And IF I get a chance to work on the machine, and I get it going I'll let you know. If I don't get back to you before the 1st., Have a Happy New Years.
    Connie
  • john-jen Dec 24, 2008
    I had the same problem with botton stitching. It looks horrible, I have adjusted the tension, it is currently on 6. My top looks great, the owners manual does not cover this?? Thanks, Jen Allen
  • Anonymous May 01, 2009
    I think I need to adjust the bobbin tension. I have a brother ex-660
  • Brother Master
  • 1,388 Answers
If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
Have tried to sew with my brother sewing machine a - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Dec 11, 2008
  • Hassy
    Hassy Dec 22, 2008
    If
    Top (spool) thread loops underneath work = Top Tension problem.
    If
    Bottom (bobbin) thread loops on top of work = Bobbin Tension problem.
    Check your bobbin is wound with good tension and not too loose as this can cause troubles.
    Use a Sharp new needle.
    I still maintain that there is probably some tiny piece of lint or thread keeping the tension looser than it should be.
    A good "flossing", like your teeth, for the Top Tension if the looping is on the underside
    If looping on top, carefully undo the tension of the bobbin case and dismantle........lay out the bits in order and alignment, take photos if it helps, check for lint, clean and re-assemble.
    This is not a job for Christmas Eve !!
    I have some arrangements to conclude myself now, so all the best for the season.
Bobbin thread loops
try adjusting the top tension, one number or letter at a time on a
piece of scrap fabric till the bobbin stitches don't loop any more
here is a free manual just incase you don't have one, just click on
the link
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Nov 12, 2012 | Brother XL-5340 Mechanical Sewing Machine
The stitching is not right. It looks fine on the top of the fabric, but bunches up on the bottom
Looping or bunching on on the bottom is a result of problems with the TOP TENSION.
Rethread the upper thread and adjust tension. Try again.
Jul 05, 2012 | Brother CS6000i Computerized Sewing...
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
When the machine is sewing with black embroidery thread, it will have big loops on either the top or bottom when sewing an outline and will also "nest" and the upper thread will break. Black...
Try a different black thread, quality can change a lot on threads. Also...black color is the worst for tension issues due to the overdying done to get a real dark black color on the thread. Looping on the top and the bottom are two different issues. Double check all threading when you have problems. Also the white is a brother pe100 clone. You may find a solution on a pe100 brother page or site.
Jan 15, 2011 | White Sewing W3300 Computerized Sewing...
Thread loopy on top
General rule of thumb::
loops on the bottom, problem on the top.
loops on the top, problem on the bottom.
It sounds like your bobbin thread is not thru the little tensioner in the bobbin compartment.
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
Bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Apr 26, 2009 | Brother SE-270D Computerized Sewing...
Thread looping onto itself
when i try to pick up the bobbin thread it does not pick it up at all i even try threading it all back over many times can yuo help me please
Oct 05, 2008 | Brother XL-3500
Brother LS-1217 Mechanical Sewing Machine Logo
261 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
