Question about Compaq Presario Notebook
Flashing lightning bolt on Compaq C300
I have Compaq C300. The lightning bolt repeatedly flashes. Is the battery bad or do I have a power connection problem? Background: The household cat ate through the AC power cord. The system ran for a while and would shut down indicating that it was running on a dying battery. I have replaced the power supply and now when I connect it the system fan come on for a perhaps a second and the start up lights flash orange then the system shuts down and the the lightning bold flashes orange. When I press the power button the system seem to want to start up and the light on the power button flashes organge for a few seconds and then shut off leaving only the lightning bolt flashing. Is this a power supply problem or a battery problem?
  • 2 more comments
  • cglancy57 Dec 09, 2008
    Thank you all for your speedy response. I have removed the battery and have attempted to boot up the system but to avail. The amber lightning bolt is still blinking but before the blinking followed a consistent pattern. Now it blinks in an irregular pattern. The system has been idle for several months. Is there a clock battery in the system that may have also become depleted?
    The power cord is the exact replacement model number for the power cord that came with the computer. Both are 18.5 volt. 3.5 amp adapters. I ordered the replacement based on the model number.
  • cglancy57 Dec 10, 2008
    No upgrades.
  • bellanca guy Jan 03, 2009
    I have the same problem. I have different batteries and diferent power supplies and still the same problem. We are well past the "is it plugged in" question here guys! Does anyone have an idea other than a guess?
  • 38 Answers
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Posted on Dec 09, 2008
    Sergeant:
    Champion:
  • 258 Answers
I think the battery is depleted so the power supply can no longer charge the battery
  • Efren Javier
    Efren Javier Dec 13, 2008
    my final conclusion would be both battery and power cords have problems first, the power cord doesn't chrage the battery causing the battery to ran out i think you just have to replace the cord
  • 107 Answers
Try turning the system on with the battery removed and the power supply connected, cause it sounds like you power supply is not working
  • Eric Mitchell
    Eric Mitchell Dec 09, 2008
    can you give more information on the power cord you got for it
  • Eric Mitchell
    That power cord meets the requirments but you system is lacking power have (sense this happend) you upgraded anything in the laptop?
Computer will not turn on but has flashing lightning bolton front of computer what does this mean
Is there any beep coming from the computer? What are you doing before it happens? Any changes made both on Hardware and/or software? These flashing lights indicate that there is something wrong with a hardware. Please provide specific questions and I will try to answer them.
May 21, 2010 | HP 435768-001 - Compaq Presario C300...
Flash wont work and lightning bolt flashes when trying to take the picture
The flashing lightning bolt is your camera telling you it's trying to charge the flash but can't get enough power from the battery. Is the battery old...been charged many times...neglected and left to completely discharge? Any of these things can reduce the capacity of a battery.
Jan 19, 2010 | Canon PowerShot A530 Digital Camera
When i push the power button on my compaq 3000 it and the lightning bolts flash 3 times and then nothing , i have a brand new cord and battery
There seems to be a problem with charging your battery. Please remove the battery, connect the power adapter and turn on your PC. If it works, test with battery alone. If possible, check your battery in a simliar laptop to make sure if there's a problem in the battery.
Sep 28, 2009 | Compaq Presario Notebook
Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
May 27, 2009 | Compaq Presario M2000 Notebook
Compaq presario c300 wont turn on at all
Looks like a bad motherboard ,have you tried another power adapter the one that connects to the wall socket.
The motherboard could cost over $100 ,chepaer on Ebay or you could take it to a Compaq/HP service center and ask for a quote on the repair.
May 13, 2009 | HP Compaq Motherboard
Compaq laptop won't turn on
Take out the battery completely and only hook up the adaptor and see if it turns on then. If it turns on then your battery is bad. If you try both adaptors and get the same flashing lights then the motherboard is bad.
Feb 04, 2009 | HP 435768-001 - Compaq Presario C300...
FLASHING AMBER UNDER LIGHTNING SYMBOL
Is it an amber lightning bolt? (I am assuming thats what you mean by UNDER lightning symbol)
That is the charging symbol for your battery, it means your battery is being charged by your power adapter.
Jan 29, 2009 | Compaq Presario X1000 Notebook
No problem? ?? HP dv8230 status indicator lights flashing.
I believe this would mean that your battery either has a low charge or if you have the AC power cord plugged in, it could mean your battery is bad and won't take a charge
Jan 05, 2009 | HP Pavilion dv8230us Notebook
Compaq Presario c300 power light blinks..
It sounds to me like there's a short in the AC adapters causing it to have enough power to charge the unit when it's not pulling power, but once it starts pulling power, it basically becomes overwhelmed and can't do both power and charge. There's also the chance that the DC jack [which the AC adapter plugs into] is bad. However I'd suggest checking the adapter first because it's simple to obtain a new one and if it doesn't work, you can most likely just return it and say it doesn't work as opposed to a dc jack being repaired which would have to be done by a professional with the skills to handle it [of course unless it's under warrenty, less than a year old, but judging by the model I'd say it's probably not]
Nov 27, 2008 | Compaq Presario Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Compaq Presario Notebook Logo
2,982 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
