Question about SanDisk 4GB microSD High Capacity Memory Card
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I put the micro hc 4gig sd in the adapter, but my usb card reader does not recognise it, and also my toshiba laptop sd slot reader does not read it either, all my other normal sd cards work fine, and they are up to 2 gig sd cards, I purchased this 4gig micro,hc card for my mobile Phone, any help would be much appreciated
  • 7 more comments
  • harry a Dec 11, 2008
    i have a 4GB sandisk micro sdhc card and my laptop my camara and phone will not recognise this
  • Anonymous Dec 30, 2008
    tried using several adapters and other pc's no luck. cell reads it no problems
  • I Need Help9 Jan 03, 2009
    word for word the EXACT problem!! Even the toshiba laptop!
  • Anonymous Jan 04, 2009
    I have the same problem:/
  • Anonymous Jan 09, 2009
    thanks... you wouldn't happen to know if the LG Rumor reads it or not?
  • snorelax Feb 06, 2009
    wow i have the same problem my laptop though is an acer but my sandisk 4gig hc microsd came with a little adapter usb for hc sd micro sd. i tried a sd adapter and several other computers. i tried reformatting it on my cell phone and nothign gives camera doesnt help either and it even slows down my phone a bit when i put the card in my phone what could possibly be the problem?
  • saucychik977 Mar 25, 2009
    my computer is not reading my micro sd
  • wavehead Apr 10, 2009
    I was told to download the latest firmware for the device you want to use .... for more info see here ...
  • noorbhadella Apr 12, 2009
    I put the micro sd 4gig in my nokia 6300 and it says that my memory card was not formatted but i formatted it and it still says that it was not formatted and i cannot access it in my phone
  • 57 Answers
Does the micro sd card been detected by your computer? If not, you may try other card reader, or other computer. If still does not detected, you may try to go to device manager and see whether the sd card is there, if yes, then you can assign a drive letter to the sd card.
Once SD card shows as a drive letter on PC, you can download sd card recovery software to get back your files. recommended asoftech photo recovery that helped me before. download it from link below
SD Card Recovery Software
You can refer to this card recovery tutorial
Recover files from SD Card
If above does not work, you may have to format the memory card (use quick format), and then use Asoftech Data Recovery to scan again the memory card and recover your files.
Posted on Mar 04, 2013
  • 119 Answers
The problem is that a 4 GB micro sd card is HC (High Capacity). You will need to buy a card reader that can read HC micro sd cards (cost +/- € 8).
Very important: check if your mobile phone works with high capacity micro sd cards because a lot of phones don't work with HC micro SD cards.
Don't forget to rate, thks
Posted on Jan 08, 2009
    New Friend:
    Problem Solver:
  • 6 Answers
SD cards are not created equally! There is so much more to know than just the capacity.
There are many things about SD cards most people are not aware of. After having numerous problems with my cards, I thought I would share what I learned, mostly from online articles, trial and error!
There are SD cards (Secure Digital)
SDHC cards (SD high capacity)
and SDXC cards (SD extra high capacity, high performance)
Speed Class: There may be a C with a number inside the C printed on the card, (or a U with a 1 in it) - if there is no C or U on your card, it is a C2 card.
C2 is for basic data and photo use and has a slower processing speed.
C4 and C6 are acceptable for up to basic video.
C8 and C10 are high performance, fast processing speeds - and cost more.
The U1 symbol indicates fastest processing speed available, and will cost the most. For large size, HD videos.
If you are trying to use a basic SD2 card (no C rating or C2 rated) for a high quality or high speed video or large RAW photo, you may have problems with your device. The card may not be able to keep up speed-wise. These are generally older, or lowest priced cards. More information and photo examples on the speed class here:
Your device will read SD cards up to the capacity it is capable of. A device with SDHC capability will be able to read basic SD cards, but might not be able to read an SDXC card, so you may think you have a defective card when you actually just have a device that does not have the capability to read it.
If your computer's SD reader or peripheral card reading device has an SD card reader and it cannot read SDHC (high capacity) or SDXC (extra high performance/capacity) it will reject or not see the card and you might think you have a defective card. Put the card in your camera or other device you are going to use it for, and then using the USB cord that came with the device, plug that into your PC. The PC will be able to read the card that way, edit it, etc.
After copying all files on the SD card to your computer, you may wish to format the card before using it again. When formatting the card, IMPORTANT: Make sure you have copied all the data you want to keep onto your hard drive, and make sure it is formatted FAT32. I kept formatting a card FAT (which was the default for this card), and the recordable capacity of the card kept getting smaller...and smaller...a 2GB card was only allowing 350, 250, 125 MB of data to be stored on it! I kept hitting a brick wall trying to copy files onto it. I kept formatting the card, thinking there was some de-frag issue or corrupted portion, and the capacity of what it would store kept diminishing - until I formatted the card FAT32. ONLY THEN was the card able to store to its true capacity. I was able to do this in Windows in Explorer - right click the drive the SD card is in, select Format, verify the Capacity (card size), verify the File System (use the pulldown menu to select FAT32 if it is not selected), and then click Start and allow the computer to remain undisturbed until the format is complete. I found a web page that covers this:
There is an SD website that offers a download for proper formatting of your SD card, with downloadable instructions. I was using Windows to format my SD cards, but the SD website recommends using software that specifically formats SD cards. Here is the site: Click the Downloads section.
Some older devices can only handle smaller SD cards (2 GB or smaller), so if your device cannot read a particular SD card...check your owner's manual. There is usually a limit to the size, capacity, speed, type, etc. of the cards each device can handle.
It is also possible to partition an SD card so it can be read by more devices, or separated for organization purposes. I prefer smaller SD cards when possible to avoid a huge loss if the card becomes damaged, lost, etc., but for those who have cards that are 16+ GB in size they may want to partition them. Here is a website for that:
Hope this helps!
Posted on Jun 28, 2013
Mine was working then i the phone says you need 2 gb of free space So when I try to delete stuff It didn't work and when I tried to format it it said not allowed but when I took it to best buy they Said it deleted everything and the reader was bad so I bought a new card reader and it won't let me save anything Same goes with the new micro sd card
Posted on Jun 21, 2012
4 Suggested Answers
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
Posted on Oct 29, 2008
SOURCE: pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Posted on Jan 05, 2009
  • 251 Answers
SOURCE: Hello,
Hi , the most likely cause is your card has been flexed and this causes internal damage to it , sorry but no repair is possible , i have a sizeable collection of cards that have been damaged the same way .
Posted on Apr 25, 2010
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
I bought an 4gig SD (HC)? card for my Camera. On start up, the Camera reads "FORMAT SET:OK" but when I select OK it Says CARD ERROR!. I've traded the "defective" one in for a...
The A402 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jan 15, 2011 | Samsung Digimax A402 Digital Camera
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
Jun 07, 2009 | SanDisk 4GB microSD High Capacity Memory...
PNY Optima SD HC 8GB isnt working on laptop
Youll have to get updates for your laptop card reader or get a new one which may have to be installed. Another method you may want to try would be to put the card back into the device you used it in and then hook the device up to the computer, most likely through the USB slot....good luck
Jun 05, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
Dec 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 4gb microSdhc wont read in computer
few computers nowadays read SDHC out of the box. you will need to purchase a SDHC reader that plugs into your USB port.
May 12, 2008 | SanDisk Cruzer Micro MP3 Player
HELP w/ Sandisk 4GB MicroSDHC Memory Card with SD Adapter
First check it in ur laptop whether Card reader was installed or not.If ur laptop doesn't install drivers then Take from nearest service center and install the drivers.
Mar 06, 2008 | Computers & Internet
SanDisk 4GB microSD High Capacity Memory Card Logo
2,099 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
