Question about GE Refrigerators
Ice is building up on the back wall of my freezer
GE RZ268868 Model TFX26CRDA.
I scraped the ice out, wiped it down, emptied the ice dispenser of ice, and my freezer food is still soft.
  • 171 Answers
The freezer heater needs replacing, it's inside the freezer after removing all the racks remove the back panel, the heater is on the lower part of the condenser it's about $50.00.
Posted on Dec 10, 2008
Lg fridge not making ice all of a sudden
It just may actually be frozen lol. Try defrosting the freezer and see If it works after that
Nov 27, 2017 | Miscellaneous
GE Model PSIC3RGXBV. Inside freezer at top of ice chute, frost builds up. Returns after wiping. Happens on Humid and non-humid days. Empty nesters so doors are closed quickly. All vents inside clear.
the model number didn't come up,but if you have an air leak most likely it's gonna be the ice chute door itself not fully closing,you can get paper towels,and stuff them into the chute hole for a couple of days to see if that's the problem,another thing is open the door and put a light in front of the chute door and look down the hole,if you see light then the door isn't sealing or check the door gasket for any tears
Nov 01, 2017 | GE Refrigerators
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Built in freezer compartment only gets cold on right side and some on back, not left side, bottom or top. Is it fixable or do we replace refrigerator....GE Model GMS10AAMLWW
Try defrosting it for a day or 2, could be ice build up on the coils, just empty it, unplug and leave the door open, have something handy to wipe the water up with as it thaws out.
Aug 22, 2009 | GE GMS10AAM Top Freezer Refrigerator
The ice dispenser door does not close all the way, and frost building up inside.
You are sure about the model number listed above your post? There are many versions of that model so I just need to confirm. Has the fresh food compartment begun to warm up slightly? Is frost building up on back freezer wall indicating a defrost problem. That model has control boards that make your refrigerator more efficient. If you need more help I will give you my email address so we can communicate directly, Thanks, Sea Breeze
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Temperature to warm
that is an automatic defrost problem
timer,heater or limit switch
Apr 22, 2009 | GE Profile PCF25PGW Side by Side...
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
245 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
