Question about Williams Heating & Cooling
Can't keep pilot lit on a 2 year old 35,000 btu gas furnace
I am commited to the idea that it is the thermal couple but and am prepared to change it out but it looks like their is know easy way to get to the end that is near the flame. can you give me directions on the best easiest way to accomplish this task. the funace again is a wall mounted williamsgas furnace
  • 19,396 Answers
You need to test the thermocouple, to test a thermocouple, you heath it up, and at the same time read voltages and continuity at the terminals using a multimeter.
Posted on Dec 09, 2008
I have an old gas furnace. The thermostat is working but the burner won`t ignite. It`s 40 + years old but has been maintained it`s whole life. A new furnace is not possible at this time.
You should have a thermocouple in the unit for the pilot light. See if the pilot is lit, if not you may need to replace the thermocouple, if it is then check the voltage to the gas valve, if you have volts 24 volts there, your gas valve is bad. If you do not have 24 volts to the gas valve, then it's probably a limit switch.
Dec 18, 2016 | General Electric Heating & Cooling
Pilot stays lit but burners dont come on
Burners could be clogged from previous years of use- turn off pilot-then gas and remove and clean burner then replace and follow your steps backwards then start system
Oct 04, 2016 | Intertherm 56000 Btu Gas Furnace
How to wire a gas valve and thermosat
We need more information. Is this a 30 year old furnace or newer one? The safeties vary greatly.
Nov 22, 2014 | Williams Wall Heaters: 35,000 Btu/hr...
Empire wall furnace pushing down the pilot button trying to light the pilot found too much gas flowing
Is the button on the gas valve or a red button in the line to the pilot assembly? If its in the line, there is a regulator upstream of the button. If the gas is coming from the gas valve, there is a small screw covered hole in line with the pilot line in the gas valve. If neither of these apply, you may need to replace the orifice in the pilot assembly. Let me know how it goes.
Nov 19, 2013 | Empire Comfort Systems Direct-Vent Wall...
I can't keep the pilot lit. I replaced the
Not sure if this will help but maybe to much gas pressure?
Apr 26, 2010 | Teledyne Laars Laars Lite2 Heater 175000...
Is it possible to find parts for old Coleman floor furnaces? I have a 35,000 BTU, Colman Super Performance gas furnace model 22. It's old but operates great. My concern is on the cracked glass in a...
Dear Sir,
That glass inspection cap is not made anymore, and it is very dangerous to operate with out one in place. Many people are in the same spot as you are.
I have had success working with glass companies, they can make a glass piece out of glass that can withstand high heat, it is time consuming and expensive, so you will have to shop around, but it can be done, but not for cheap.
Those old floor furnaces can heat so nice, Just for the information these floor furnaces are still being made, though they heat a bit differently as they don't get as hot, just a new code put into place, to keep children from burning thier little feet.
"Cozy" is one of the new manufactures.
I hope I have answered your questions.
Sincerely,
Paul Gibson
Mar 30, 2010 | Coleman Propane Forced Air Heater...
We have a teledyne gas furnace whose pilot won't stay lit. Any ideas?
Is this a standing pilot,or pilot always on.
If so a bad thermocouple will cause pilot to go out.
Thermocouple is a small copper tube running from the pilot light area to the gas valve. easy to replace.
Jan 14, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Coleman Gravity Floor Furnace need millivolt gas valve & pilot ki
Go to www.grainger.com and look for a "power pile generator" this is a millivolt thermocouple that may be just what you need to make your heater work again
Nov 12, 2009 | Heating & Cooling
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
51 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
