Question about Sharp XG-C60X Multimedia Projector
Blue blob on screen. Blob is visible even in Picture Mute
We have 2 of the projectors that ppear to have a sever problem with image retention in the blue channel. Brite images are slow to disappear.
Tnx
Jacky
Sharp Factory rep told us that it would cost more to fix it than replace it. SO that is what we are going to do.
Posted on Dec 10, 2008
A yellow blob in the middle of the picture and it seems to be growing
1,check it ,clean the Lcd panel with alcohol, maybe the yellow blob will disappear
2,if it is not,it seems that the LCD panel is failing
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | Panasonic PT-LB60NTU LCD Projector
The screen shows multiple tiny dots. (stars)
Are they sharp and defined, or 'blob'-like? If they are sharp, that would indicate a faulty DLP block (not worth repairing, unless under-warranty.) If they're more 'blob'-like, it's probably just dust in the optical block. That can usually be remedied by removing the lamp, and blowing-out the unit with an air compressor. Canned air won't do the job, as there's not enough pressure.
Apr 26, 2013 | Dell 1410X DLP projector 2700 ANSI...
Eiki LC-XC1 color problems
check all the optical parts around the blue lcd-panel, they might be darkened due to heat
May 07, 2012 | Eiki Office Equipment & Supplies
I have a Hitachi CP-S240 projector. It works fine but now projects a yellow blob on the screen. It looks as if someone took a highlighter and colored on the lens - I cleaned the lens and that is not the...
I work for a company where we take care of around 7,000 projectors. We have recently come across this same issue in this model and several other Hitachi models. We have figured out that it seems to be a main board issue, after testing and checking of the lenses and other things. The main board ended up being the fix. Hope this helps!
Apr 12, 2011 | Computers & Internet
I have a Sony lcd data projector- VPL-SC50.. There is a big black blob in the middle, with other lines near the edges. And the blob is growing larger now. But it does not look like a burn out, it looks...
Normally a "blob" on an LCD is a delamination of one or more of the LCD panels. But, they are usually not black. You may have a poor ribbon cable connection from the main board to the LCD panels....there is a ribbon connection to each of the Red, Green and Blue panels. It's either that or a main board failure, but certainly soemthing you want the factory or other authorized service center to check out.
Good luck.
Aug 12, 2010 | Sony VPL SC50 projector lamp Projector...
Have changed the bulb because of yellow blob on the picture and it has made no difference
the yellow blob is from a fried polarizer on the blue lcd panel due to excessive dust and heat. you'll have to replace it, but hitachi doesn't sell individual optical engine parts, so you may have to replace the whole optical engine.
Jan 18, 2010 | Hitachi CP-X440 LCD Projector
Hitachi dlp - 52" . neon blobs
Hi, the convergence chips on the board are showing signs of failure. simply replacing the board will fix this issue.(convergence board failure)
May 14, 2009 | Hitachi Televison & Video
Greenish/Yellow spot
Sounds like a scorch mark on the polerising filter, this can only be replaced by an engineer cost around £70 ($150).
Marc Engineer
Apr 05, 2009 | Mitsubishi LVP-X300 Multimedia Projector
Screen
Sounds like you LCD has gone bad... Its like a calculator LCD when you press down on the screen of it it get like a blob. My projector also has done this... Half of the screen is all blue
Sep 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
Hitachi 50v500
To all that are experiencing the blue blob. This is result of poor maintenance. Projectors must be kept clean on all air intakes. This is to help you all understand the failure cause. Usally not worth repairing.
Aug 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Sharp XG-C60X Multimedia Projector Logo
129 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
