I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging...
(More)
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging is wire up the low voltage for the heat pump. I can't seem to find out where the wires go from the heat pump. It has 4 wires: Brown
I have a similar problem. It gets up to 78 degrees in the house and the ac unit is set to 65. It...
(More)
I have a similar problem. It gets up to 78 degrees in the house and the ac unit is set to 65. It sounds like it is on all day and my electric bill is rediculous. I have replaced the filter, but have read things about cleaning out the outside unit. Does anyone think that this will help? If so, how do you go about doing it? My duplex management wants to charge me money to send someone over here to look at it...
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut...
(More)
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut off. a/c comes on, and get cold, but blows on low. seem like the switch is switched to on, instead of auto.. CVould this be control board? Thanks
I have a ruud ac unit running heat for the second time this winter and now not heating. blowing cool...
(More)
I have a ruud ac unit running heat for the second time this winter and now not heating. blowing cool air
