Question about Optimus Audio Players & Recorders
My Optimus STA 3190 has no AM/FM
I have tried everything that I can think of. When switched to AM or FM nothing happens but static. Everything else appears to work fine. I don't want to spend a lot of money on this unit Can you help
  • David Ford
    David Ford Dec 10, 2008
    aerials connected, went to radio shack and bought new one. Have a manual and tried everything short of taking to repair shop
  • 1,512 Answers
Hi rowdy
The fact that you are getting static at least is good. Without knowing allot of the background to your problem, first thing to check is if the aerials are correctly connected. If it is any help to you, here is an excerpt from the original owners manual about the connection of the AM loopstick.
If the aerials are coinnected right, then let me know and we can investigate other options. Cheers
Posted on Dec 10, 2008
My Optimus STA 3760 Receiver will not play any sound on tape monitor, and will only play the right channel on the phono setting. What could be wrong with it/ how do I fix it?
Chemically clean all of your input selector switches and see what happens. If still have issue then one of your amps is in need of repair.
Sep 08, 2017 | Optimus Audio Players & Recorders
I can't get my tuner to work, but everything else works fine. All I get is static went I turn to the radio stations on both FM/AM
If you are in a fringe area you might need an external antenna to work with your tuner. Happens.
Oct 15, 2015 | Pioneer VSX-D704S Receiver
We have a Optimus STAV-3770 that is stuck on 'Muting'. Have tried everything we can think of to no avail. Even purchased a new remote.Is there a solution.
Switch off the mains supply before connecting/disconnecting any cables.
Disconnect all the speaker cables and switch on. If the fault clears carefully check the speaker wiring for shorts before reconnecting.
If the fault is not in the speaker wiring or speakers the amplifier will need expert attention. Faulty speaker wiring can easily damage solid state amplifiers.
Aug 03, 2014 | Optimus Audio Players & Recorders
Sta 3190
Check amplifier IC, check all board solder for dry one's.
Feb 12, 2014 | Audio Players & Recorders
Lost all radio stations on my Sherwood RX4030R
It certainly sounds like the main tuner has failed, if IC301 does that function I would replace it and see what happens.
May 25, 2017 | Sherwood Audio Players & Recorders
I have an Optimus STA-3500 Digital Synthesized AM/FM Stereo Receiver. If I buy an i-pod is there a place on the back of the receiver that it can be plugged into? If so, what kind of i-pod wire/cable...
It won't have "iPod" functionality but it can be played through the receiver.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here:
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 25, 2011 | Optimus STA-3500 Receiver
I have a Optimus STA-3750 am/fm stereo receiver and using a universal remote. I need to know how to program it with the features like changing the sourceces
I have the same receiver, but have been unable to program it with my Universal Code. I do not have the original remote. Did you find a code that controlled it? I found one website that had the owners manual online, maybe that would help:
Nov 06, 2009 | Optimus Audio Players & Recorders
I own a bose radio/cd (top load) with pedestal. Last night one lightning strike affected power in my home before I could get things disconnected. Now with everything reconnected, my radio FM and AM is very...
The tuner section may have been toasted by the power surge that affected your home. See if there is another option for an antenna connection and try that. If not, then it does not appear you have much choice.
U might want to contact Bose for an authorized factory repair station in your area.
Apr 01, 2017 | Bose Wave Radio
460 people viewed this question
Top Optimus Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
