Question about Canon imageCLASS D880 All-In-One Laser Printer
Canon imageclass d880 continuance problem with incorrect paper si
I keep getting incorrect paper size on my canon and I cannot figure out how to correct it. I do not have the printer connected to a computer, I purchased it for small business purposes and I basically use the copier and the fax. Needless to say, the fax and copier will not work properly with the LEGAL size paper setting and I need to know how to change it without connecting it to a computer. If you can help I would appreciate it. Thanks. Felecia
  • 4,472 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=10516
If you follow this link you can download the guide for your printer. If you refer to p.65 and p.66 it gives you visual step by step instructions on how to adjust the paper size. If you still need further assistance please let me know.
Thank you,
Lee
Posted on Dec 09, 2008
  • Canon Master
  • 6,487 Answers
If the using the menu of the printer lcd still didn't fix the problem, the only way you can make this work is to conenct it to a computer then after that adjust the settings of it...
  • 169 Answers
From the Canon USA web site:
To set a fixed paper size: Press <Additional Functions>, then select [COMMON SETTINGS], [MP TRAY PAPERSIZE], [ON].
Choose the appropriate paper size from LTR, STMT, CUSTOM PAPER SIZE*, A4, B5, A5, or LGL.
Rate this FixYa if it made things all better :-)
Carl
Can i use cardstock paper in my canon imageclass d880?
There maybe an adjustment on the rollers for different types of paper grades. If so adjust it for heavier paper weight.
Mar 02, 2012 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon d880, Have tried every way to get paper out, but can't. Need to know what to do?
Make sure to blow off the optical device near the print head.
It may not have a paper jam at all.
Apr 07, 2010 | Canon imageCLASS D880 All-In-One Laser...
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in front roller of imageclass D880 (about 1/3 inside)
dirty pick up rollers. take the paper tray out and them you will see 2 half moon rollers, clean them with alcaho and you will be ok.
Oct 08, 2009 | Canon imageCLASS D880 All-In-One Laser...
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam that I cant get at
the paper must be jammed in the fixing assembly.
you are gonna have to remove some screws to remove the plastic covers. once you took them off proceed to unscrew what ever needed in order to free the fixing assembly, which is the one located in the upper back part of your copier. once you released the fixing assembly release the springs and remove the metal stoppers. now you should be able to remove the paper jam. good luck!
Jan 27, 2009 | Canon ImageClass D880 Copier
Canon imageCLASS D880 All-In-One Laser Printer Logo
128 people viewed this question
old marine
old marine
