Question about Kenmore 63942 Dryer
Kenmore 80 series runs but dont blow hot air
Is this heating element
  • 2 more comments
  • asotolp Dec 11, 2008
    Dryer turns on, all, except the heat, seems to work ok. It just wont heat up
  • Anonymous Dec 15, 2008
    runs but i cant get any hot air
  • Anonymous Jan 02, 2009
    We get a little heat if we use the 2 lower settings but as soon as we try to use the 2 higher settings, we get no heat at all. What could the problem be and is it easy to fix by yourself?
  • Leslie Oct 27, 2012
    I have a good fix it posting for the 80 series gas dryer but accidently posted it under a problem with the electric version. Check it out, our dryer finally works! Leslie
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Posted on Jan 02, 2009
I had the same problem. The heating element is most likely broken. It is an easy fix and costs about $75-$100
Posted on Dec 12, 2008
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Posted on Feb 12, 2009
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
Kenmore dryer Part# 8562458 Series 80. not heating, glow bar is not getting hot.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 25, 2010 | Kenmore Dryers
Feb 12, 2009 | Kenmore Dryers
Dryer don't blow hot air, everything else runs ok.
you need to check the heating element and the thermal fuse to see if they are blown.
Dec 19, 2008 | Kenmore 659 Electric Dryer
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
2004 kenmore 80 series dryer all electric
ckd thermal fuse on element housing ..then element for continuity but also could be timer contacts or switch on motor but ck for burnt wires and 220 volts at back of dryer
Jul 21, 2008 | Dryers
Kenmore 63942 Dryer Logo
3,800 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
