Question about HP Compaq Keyboard, Trackball
Diagram showing placement of spring inside Compaq mouse.
I have a Compaq mouse, model N3 ball. When I took it apart to clean it, the spring popped out and I can't figure out exactly how it needs to sit.
SOURCE: MOUSE CAME APART INCLUDING SPRINGS HOW DO I PUT IT BACK TOGETHER
The Spring goes on the right side of the mouse wheel as it would be pointing at your computer. It supports the wheel to make it spring back when preasure is applied. Place the spring on the axle with the spring forming an spread out "A" (not a "V"). You will see that it falls nicely into the 2 little tower mounts. my real problem was with the other little piece of bent wire that fell out. This is the part that makes the snaping fealing as you scroll the wheel. This connects directly on the plastic part that is mounted on the scroll wheel. If you look at that plastic part you will see a small hole. One end goes in that hole & the other rounded end goes to the splines on the wheel itself. I hope this helps, it better that just saying go buy another.
Allen
Posted on Jun 25, 2010
SOURCE: cant get it back together
Thanks for this posting. I didn't even think it would be the battery and was nervous to pull everything apart, but it was easy thanks to the information from Solution #1.
Posted on Nov 04, 2008
SOURCE: Spring placement for scroll wheel
Found an answer with pictures on the site.
Posted on Mar 26, 2009
graysand
  • 558 Answers
SOURCE: hp mouse model # n3 ball middle button is not working
Do you have the install cd.Try reinstalling the software.
Posted on Sep 23, 2009
aimrans78
  • 52 Answers
SOURCE: I have an HP GT909AA wireless laser mouse, model
that sring is of middle button try to reinsert carefully
Posted on Jun 18, 2010
Need to reinstall keys in keyboard model # 36211
http://www.ebay.com/itm/New-Acer-X1920-Black-Slim-Keyboard-M-N-KB36211-Wired-Optical-Mouse-Bundle-/181035133203?nma=true&si=%2F%2FConeksOe5hRIsHW2VEQsodgMk%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Scroll down to mid page. They show the main view of the Keyboard, wrapped in bubble plastic.
There are smaller views underneath.
Click on the 4th view from the Left.
Shows the key placement.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 13, 2012 | Acer Aspire Ax1430g-uw30p Amd E-450...
I have a model 21a- 410-062 MTD tiller that i had to replace the shifting forks on. The trouble is I cannot figure out hoe to get the shifting clutch collar back on the shaft or i don't know how it goes...
there's a pretty good schematic here:
http://www.m-and-d.com/pdfs/MTD/410-420.pdf
and a reference diagram here:
http://int.custhelp.com/ci/fattach/get/15094/1173195151/session/L2F2LzEvc2lkLzJPNmdRanNr
I've had mine apart twice, first time to replace the shifter fork, 2nd time to find why it keeps popping out of gear.
Apr 20, 2011 | Garden
G-3050 - area to draw soap - how to put washer/ball and spring
First off you must be using the low pressure nozzle for the chemical injector to work. It will not work on high pressure. The spring goes into the injector body first with the ball in metering valve.
Apr 17, 2010 | Karcher 2500 PSI Pressure Washer
Am trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like.thanks!
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.
What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.
I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.
Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
Apr 05, 2010 | Generic Memory Mini Retractable USB...
Sticky, dirty rollers
There are 2 ways to clean the rollers.
  1. From underneath you can unscrew the piece holding in the trackball; from here my tool of choice is a pencil eraser. Rub away at the gummed up rollers until you are sure they are clean.
  2. Unscrew the mouse and take it apart. You will find the rollers will "pop" out of their clips (be careful not to apply too much pressure or you can break a clip). Once out, it's very easy to clean the rollers thoroughly. One of the rollers will usually be spring loaded so keep an eye on the spring when disassembling. The process for putting the rollers back is just as they came out with the spring loaded roller put back last (easier to place other rollers first as they don't move once they are in. Once the rollers are in, re-assemble the mouse, replace the trackball and you're in business.
I've been doing this with my old USB mouse for years, still working great after 5 years!
Hope this answers your question and best of luck to you!
Greg
May 23, 2009 | Logitech 9311570403 Mouse
Spring
the spring with the loop in the midel gose on the right of the weel the other one whit the square bent on one side gose on the left side essy to figure out
Jan 23, 2008 | Computers & Internet
Put back togather
Well I did it. It's not exactly easy to describe. I accidently took mine apart trying to clean the roller ball and out popped the 2 springs. I sort of put it back together in "reverse". In other words, I put it together without the scroll device and then looked through the hole. By doing this, I figured it out -- when you know it's simple but to describe it without pictures is almost impossible. Mine works fine now but I don't know how to help you.
Jan 13, 2008 | Logitech Cordless TrackMan Optical...
Computers & Internet Logo
285 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
