Question about ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor
Blank screen with intermittent operation
I get a no video signal when the computer is off, when I boot it shows the boot screen for a second and goes blank, I enter PW it woes to welcome screen comes on for a second than goes bland, if I power it off, wait a min, then power it on the screen comes on beautifully then goes off. green power light remains on, every once in awhile the screen will come on for a sec.
any ideas?
  • J Long Dec 09, 2008
    thankyou for such a fast response, for some reason suddenly now it is working perfectly ~lol~
    use compressed air bursts on each till it comes on to find out which one it is if it happens again?
  • hcl0504 Jan 24, 2009
    I got same problem on my Optiquest-Q9. May I know which capacitors and what the specification of capacitors are I need to replace? Thanks,
  • 558 Answers
You have bad capacitors in the power board inside the monitor replace these and the monitor will work fine
Posted on Dec 09, 2008
  • Scott Hill
    Scott Hill Dec 09, 2008
    yoru capacitors are overheating and likely will continue to give you problems replacemetn of the bad caps is advised.
    have a great evening
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
Computer boots up shows windows xp and start up then monitor goes black if i switch it of and on it comes on for a couple of seconds and displays desktop then goes black have tried another monitor same...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 14, 2010 | Computers & Internet
Screen goes blank after afew second on ac inly
Try booting to the Safe Mode (F8 at boot) see if you get any further. Also, does the system complete boot (DO you hear windows sounds?) or is the system just hanging after the Splash screen (You can also try an external monitor and press Fn+F8 to enable the external display) If you can get video externally, then is it likely a LCD or video card failure. If you can't boot to the safe mode and you do not hear the Windows Welcome sound that normally plays at the desktop, then the system is not booting and you have either a hard drive failure and/or an operating system failure.
See if you can boot to the BIOS (F2 at boot), then reload the default settings and reboot.
If you suspect the OS is a problem, boot to the XP CD, then run CHKDSK /R and see if that helps
You can also run system Diagnostics by pressing Fn+the Power button
Dec 21, 2009 | Dell Latitude D800 Notebook
Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Apr 09, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
XP Service pack 3 will not boot with NVidia Geoforce 6600 drivers
There's a chance that your screen resolution is set higher than your monitor can handle. Try booting into safe mode and see if you can resolve the problem. You may also have to configure the BIOS to use the expansion slot that your using for the primary video, and turn the integrated (on-board) one off. (If you haven't already done so)
Jan 05, 2009 | Nvidia GeForce 6600 Graphic Card
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
No input signal
Check connections, Hertz rate, and settings (if you can read them). Otherwise, it may be time to whip out the cash and get a new monitor and/or computer.
Aug 17, 2008 | Computers & Internet
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
ViewSonic Optiquest Q9b 19" Flat Panel LCD Monitor Logo
926 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
