Question about Home
Triton T80si shower will not switch off
Triton T80si shower turns on and runs but will not then switch off and the water keeps running.
  • 5 more comments
  • efn3 Feb 26, 2009
    And so the solution to this would be???
  • thecarrs May 21, 2009
    I have a similar problem and the water continues flowing even when switched off on the pull-cord, however I have discovered that if the pressure is reduced, by operating a tap this stops the shower. Sometimes there is water starvation, no flow at all but after a few seconds the shower operates as normal
  • Robert Gray Aug 24, 2012
    Hi, my electric Triton shower is letting the water out even when it is off, How did you fix your please??
  • Anonymous Mar 14, 2014
    triton t80si water leaking out of bottom where main pipe comes out of unit to connect to flex hose
  • Anonymous Mar 19, 2014
    triton t80si water has stopped flowing have fitted new solenoid valve two months ago electrics seem fine any suggestions
  • Anonymous Mar 23, 2014
    just bought a triton alicante shower and it only runs slightly warm
    Water pressure is good just been installed but runs cool
    Scholar:
  • 44 Answers
Its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • Nicola Conroy Dec 04, 2011
    how do we fix this problem ?
Cartridge to be remoed
Posted on Mar 20, 2010
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
Unpredictable water temperatures!
i am not an expert but i have a hunch it could be the tempeture gauge but i have no solution sory
Jun 19, 2012 | Home
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
Triton t80si shower is very hot even on a low setting then fluctuates between hot & cold, pressure switch is not activating but pressure seems low any advise will be gratefully received.
If the water temp is fluctuating from very hot and cool the problem could lie with a blockage in the inlet to the shower, scale inside the heater can, shower hose needs replacing or the shower head needs to be cleaned The problem is a "slowing" of the water across the heating elements which causes the water to pick up too much heat
Jul 09, 2010 | Home
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
3,119 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
