Question about Bernina Artista 180
Broke a needle
I was sewing, hit a pin and broke a needle. When I put in a new needle and tried to sew the upper thread keeps getting caughter in the bobbin area and looping and finally breaking. I have tried everything I know.
  • 202 Answers
Best scenario is that the needle hit deflected and hit the hook that the bobbin snaps on to. When needles hit hooks they can leave a mark or burr that the thread will catch on when it comes around. Take out the hook and run your fingernail over the edge from the point back. If you find a burr get some crocus paper (very, very fine sanding paper and polish the burr off.
Next would be that your machine is knocked out of timing meaning a trech will have to reset it.
Posted on Dec 12, 2008
My sewing machine was sewing fine until the needle broke and I changed the bobbin what did I do wrong
First, check to make sure you have threaded it correctly--upper thread and bobbin.
Most likely the sewing machine's timing was knocked out of alignment when the needle hit something, possibly a pin, a thick piece of fabric, the presser foot, or needleplate. Search for sewing machine timing or take it for service.
Jan 14, 2017 | Sewing Machines
Bobbin thread will not catch. Was sewing fine. What do I do now?
Try a brand new needle--old damaged/bent needle will frequently fail to connect with bobbin thread.
If that does not resolve the issue, most likely the machine has been knocked out of time--most often occurs when the needle hits a pin or is deflected by thick fabric so it hits the needleplate or something in the bobbin area. You can search the internet for sewing machine timing or take it for service.
Jan 02, 2017 | Sewing Machines
Thread keeps getting tangled in bobbon and wont sew
try a new needle
make sure the bobbin is inserted correctly,, counter clock wise
also check the upper thread tension, also check to make sure there aren't any loose thread or lint in the tension disc area
make sure the top thread has not come off the thread take up lever
check in the bobbin area for lint or loose threads
Dec 15, 2014 | Sewing Machines
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
My Brother XL-3022 sewing machine has been running perfectly for years, then all of a sudden today I went to use it and while threading the machine I am not able to get the upper thread to draw up the...
There are a few easy and free things to check:
1- try a new needle 2- check that the needle is inserted the right way (one side has a long slot, usually this goes toward the back of the machine) 3- flip the bobbin over 4- clean any stray threads/fluff in the bobbin area
Another possibility is that the machine's timing is off- the bobbin thread isn't in place to be picked up at the right time- and that would need to be fixed by a sewing machine mechanic. But if this started suddenly, and not after hitting a pin or otherwise jarring the machine, then it probably can be solved with one of the easy/free solutions above. Good luck!
Mar 05, 2011 | Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Bobbin thread getting jammed
kyoungblood4
Are you making sure that your pressure foot is up when you thread the upper thread? If it isn't then your thread is not seating correctly in the tension disks. It will then be loose and make a birds nest(mess) under what you are trying to sew. The other thing to check is which way you are putting the bobbin into the bobbin case, different machines do it different ways. Some want the thread to come out of the case in the same direction as the slot on the case and some want it to come off in the opposite direction.
Guest,
Probably when your son broke the needle he knocked it out of time. You will need to have a sewing machine technician to repair that.
Hope this has been helpful for you bothl Liz M
Aug 07, 2008 | Sewing Machines
Sewing Machines Logo
164 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
