Question about Samsung SGH-U700 Cellular Phone
Phone charging problems
My samsung u700 won't charge with any charger. can this be repaired? can i do this myself? if not how much will it cost?
  • 75 Answers
Change the charger port..or else battery may be dead..
Posted on Dec 10, 2008
SAMSUNG CHARGING PROBLEM
Many samsungs will only work with the Samsung charger because they need a very specific voltage / amperage. Lower cost charger have more variable power levels which confuse the phone. Either find the original Samsung charger, or pick up a higher quality charger.
Apr 24, 2014 | Samsung Cell Phones
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Samsung C3010S is not charging. No indication or reaction when charger is plugged. Battery and charger is good, tested it on other units. What would be the possible problem of my unit and can it be...
If the battery and charger are tested and they good...the problem will be in the mobile charging
connector,it might be needs to repair or replace a new connection base.
But first clean the charging connection by a teeth brush with Alcohol,
Sink the brush in Alcohol and clean the connection as you clean your teeth and make sure
you remove the dark color stucks on the charging connector.
I think the mobile will charge after you do this.
Jun 18, 2011 | Samsung Cell Phones
Charging error.stop charging my sony ericsson k800i
As if your using sony ericsson K800i some mobile phones as this problem as myself also faced the same problem sony ericsson mobile shows this error if you charge your mobile using connector or unsupported charges.You visit your nearest service center of sony ericsson and ask then to give branded sony ercsson charger for your mobile.After taking that charger you will not face this problem any more..your mobile is just perfect as new.Your connector or charger is having some problem with it. Charger may cost you around 300 rs. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 12, 2011 | Sony Ericsson K800i Cellular Phone
I have a problem with charging my phone. i had the whole charging socket fixed three times now but the probem still persist
you didn't tell whats the problem why your fon is not charging...Is the charger or the phone itself?if the problem is in your charger,check the wire,particularly in the 2 ends near the connector or plug of the charger.Most common problem is in the wire itself because the conductor inside it will be in the risk of cutting due to regular movement when you are going to charge.if you check the wire is good,then the problem is on the circuit of the cahrger.,most common defect is on the 3 kinds of parts,the transistor,resistor, and diodes..if you know how to use a multi tester,you can test them on their coresponding readings.
But,if your charger is good,the posible problem of not charging is in the socket or slot where the charger connector will plug in.Check if there is a loosen foot or pins of the said part..Otherwise,if its not,the problem is on the charging regulator of your cp..
Dec 04, 2009 | Samsung SGH-U700 Cellular Phone
Battery won't take a charge - says "overheating"
HI,
change your battery is the best solution before your nit will be damage.
thanks,
Jun 30, 2009 | Samsung Gleam (SCH-u700) Cellular Phone
Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
May 13, 2009 | Samsung SGH-D900 Cellular Phone
MY MOBILE PHONE CHARGING SOCKET HAS SNAPPED
You have 3 options when the charge port breaks.
2. Get a new one
3. Get an external battery charger and charge battery separate from phone. Another battery and charger will set you back about 10 dollars on ebay.
Fix for Broken Charge port on Samsung SGH-D900
Mar 07, 2009 | Samsung SGH-D900 Cellular Phone
Samsung SGH-U700 Cellular Phone Logo
147 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
