Question about Timex 27191 Wristwatch
Battery replace lights up but does not keep time
I have timex watch which I replaced the battery in. It lights up when you press the button but it will not keep time ( second hand does not move).
  • 43 Answers
This could be a problem w/the movement (not the battery). Timex's warranty covers the movement, so I would find the receipt and call Timex about this problem (they generally need info off of your receipt unless you have already registered your warranty). They will be able to fix it for you.
Posted on Jan 05, 2009
My timex expedition has lost the indiglo light but the watch still works. could it be the battery is low or is it the light?
Most of the time, replacing a low battery will reset the light allowing functionality.
Otherwise, you will need to open the watch and press the reset button shown in this picture.
These watches are waterproof, therefore you must be very careful not to damage seals. If you are not confident in this procedure, your local jewelry store will typically do this for you.
Feb 11, 2018 | Timex Watches
Timex W-225 -- the tide and temp button are non-responsive
have you try changing the battery...?
or-
did your watch has been been dropped?
Sep 09, 2008 | Timex Watches
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    Indigo light doesn't work
    It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
    Oct 02, 2012 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
    We have a Carriage watch by Timex that's my mom's (she's in a nursing home). The watch wasn't keeping time so my brother replaced the battery. It was running fine, now it's lost time....
    A second hand that pulses but does not advance usually indicates one of two problems: (1) a weak battery that provides insufficient power to the tiny motor that advances the second hand; or (2) a bit of dust or grit somewhere in the watch's gear train that is jamming up the works.
    Try testing or replacing the battery. If that doesn't work, some watchmakers can try to blow out (using very gentle air puffs, not cans of compressed air) the watch movement and/or put it on a special machine to try to unjam the gears. It is usually does not make economic sense to perform further repairs on a watch of this price range, though it is also possible to replace the entire movement.
    May 06, 2011 | Watches
    My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    Hello ,,, I changed the battery in my Timex Indiglo and now just the light is working but not the minute hand or time hands. How do I fix this I have tried two batteries already?
    Jul 23, 2010 | Timex 27191 Wristwatch
    The light was fading on my Indiglo Timex watch but it was still keeping good time, so I had a new battery installed by a Walmart employee. The light now works on the watch but the watch stopped keeping...
    mcdevito75 here, Your Timex watch is most likely an Indiglo meaning light, The battery supplies power to to Quatz mechanism for time keeping and for the light. There is a very good possibility that 1 or 2 of the contacts between the battery and the Quatrz mechanism were lost during the new battery installation. While you can"t rule out that the Quartz mechanism and or the light may be wearing down, you still have to suspect the battery even a new battery, look for a small watch repair shop in your area and try another battery, let the jewler know of your watches problem so he / she can properly install the battery and ensure the contacts between the Quartz and the battery are being made.
    Jul 07, 2010 | Timex 27191 Wristwatch
    Timex T22202 Second Hand Stopping
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Read manual carefully and learn which is ordinary seconds hand and which is chrono hand and how it affects watch battery life and movement. Rate me, please .
    Apr 13, 2010 | Timex Chronograph #T22202 Watch for Men
    The hour/minute/second hands on my Timex Ironman not moving
    It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
    Jan 09, 2010 | Timex Ironman Triathlon 50 Lap Digital...
    Timex 27191 Wristwatch Logo
    211 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
