Question about Acer Aspire 3680 Laptop
Wireless i can't use my computer with my wireless internet
    Problem Solver:
  • 8 Answers
Make sure your wireless receiver is turned on, usually it's just a switch or a button that has an image of an antenna with signal lines.
Once you're sure, right click on the wireless signal icon down in the lower right hand portion of your computer desktop and right click.
Select view available wireless networks, then choose yours from the list, click connect and enter the necessary information about your network's security.
If you don't see your network name then there is another problem.
Posted on Dec 12, 2008
Disconnecting dap 2360
Your wireless network card in your computer is failing, or the cable to the computer is bad. Because you said wireless internet, I am going to assume that you are connected to the internet via wireless nic. If your pc hasn't been rebooted for a while you may want to try a reboot and see if that doesn't fix the issue.
However, if the problem remains you will likely need to get another wireless network card.
Nov 23, 2013 | D-Link Computers & Internet
Connected to wifi but no internet connection
Wireless networks have become an increasingly popular way to access the Internet. Connecting to a wireless network allows you to browse the Internet without having to physically connect any cords to your computer.
Troubleshooting wireless connectivity can sometimes be confusing, because even if a wireless network is not able to bring you to any web pages, often your computer's wireless card will still connect to the wireless network that is being broadcast.
In other words, a wireless network will read "connected" even if it is not connected to the Internet.
Connect to a different wireless network. If there is an alternate wireless network within range of your computer that you legally are able to use (a free public Wi-Fi rather than your neighbor's wireless network, for instance), try connecting to it and browsing the Internet.
If the same issue occurs on the alternate wireless network, you may have an issue with your computer's wireless card or with your Internet browser.
If you are able to connect to the alternate network but still not able to connect to your own, the problem is most likely localized to the wireless network you use at home.
Reset all devices.
The great majority of Internet connection issues can be resolved by a simple reset of all the devices in your home network.
Locate the power cords of both your modem and your wireless router and unplug them (if you use a modem/router combination, simply unplug its power cord) for a full 30 seconds.
Plug them back in and restart your computer.
Try to connect to the Internet using your wireless network after your computer has booted back up.
If the connection still fails, some further troubleshooting is required.
Bypass your wireless router.
If your computer's wireless card is connecting to your wireless network of choice yet you are still not able to access any websites, there may be a connection issue on either your modem or router.
The easiest way to locate the problem is to temporarily eliminate the router from the network. Locate the Ethernet cable that connects your modem to your router and unplug it from the router.
Plug the cable directly into one of the Ethernet ports on your computer and reset the modem in the manner described above.
Now try your Internet connection again. If there is still no Internet access, the problem is most likely with your modem or your computer; contact the technical support department of your Internet service provider (ISP) for further assistance.
If the modem goes online directly connected, your router is causing the problem and may need to be reconfigured. Contact the router manufacturer for further assistance.
Hope this helps
Oct 24, 2012 | Cisco Linksys WRT54GX4 WirelessG Broadband...
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
Wi fi is on but still can't connect to the internet
Not only does Wi-Fi have to be on, but it has to be connected to a wireless access point (sometimes called a wireless router), and the wireless access point has to be properly connected to the internet.If the wireless access point/router has empty ports on it, plug your computer into one of those ports, and see if you can connect to ther internet then. If you can, the problem is somewhere between the wireless access point/router and the computer. Could be the transmitter part of the wireless router, could be the wireless network adapter on your computer, or could be the driver that runs the wireless adapter on the computer. If you cannot access the internet when you plug into the wireless ap/router, then you need to go one step "upstream." This would likely be the cable modem or DSL modem. Plug directly into that with your computer, and reboot both the modem and the computer (just unplug the power from the modem and then plug it back in to reboot the modem). If you can connect to the internet then, the problem is the wireless router/ap. If you cannot connect to the internet then, contact your ISP.
Feb 09, 2012 | Gateway 7330GZ Notebook
No internet via wireless but modem to computer with ethernet cable i have internet
Make sure your wireless internet is enabled on your router and that your computer supports wireless internet. Also, make sure that your computer supports the signal your router puts out.
Mar 06, 2011 | Belkin (F5D8231-4) Wireless Router...
How to setup Linksys Wireless-G Broadband Router WRT54G. I want to stetup my computer, wireless, to another computer with internet access
Have you already setup one of your computers to connect to the Internet using the wireless router?
If so you can setup the second computer the same way and it also will connect to the internet. There is no need to access the Internet through the other computer.
Sep 20, 2009 | Linksys Computers & Internet
No wireless connection
Go to Parental Control after logging into 192.168.10.1. Then make sure you have allowed the MAC addresses of the wireless clients ( machines). Reboot the router one after making any changes.
Good Luck
Dec 14, 2008 | Arris Wireless G Broadband Router (wr850g)
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
Computer interfacing
You have a computer (what manufacturer and model?) connected to a Netgear WGR614 wireless router (please confirm the router manufacturer and model) by wire or wireless?
If the computer is connected wireless is it with a wireless adapter built into the computer or added to the computer?
If it was added to the computer what is the manuracturer's name and model of the add-on device?
Has any other computer ever successfully connected to the internet using your router?
  • If so was the computer connected using a wire, if possible?
  • If so was the computer connected wirelessly?
If no computers were connected successfully to the router please provide the name of your internet service provider?
I also may need to know the city and state you are located in or other information. We probably need to configure the router to attach to your internet service providers equipment
The following are to determine if the internet service providers equipment has been successfully installed and the capabilities of that equipment as it may support connecting your router, if necessary, and your computer to the internet.
Were any computers ever successfully connected to the internet by directly connecting to your internet service providers hardware?
If yes how were they connected
  • USB cable?
  • Ethernet Cable?
  • Wireless?
  • If wireless what is the manufacturer and model of the internet serivce providers hardware providing the wireless service?
Dec 16, 2007 | NetGear WGR614 Wireless Router
Acer Aspire 3680 Laptop Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
