Question about Makita BO5010 5" Random Orbit Sander
I have a Makita Model BO5010KX. I replaced the gripe pad and now can't seen to get it back on . Lost my manual. How do I screw the 3 screws back on . I'm at a lost. Thanks for the help.
  • 23 Answers
Http://www.makita.com/en-us/Assets/images/Products/BO5010K/parts_breakdowns/BO5010.pdf
let me know if that doesnt help and i'll talk you through it. i'm guessing you just forgot the order the pieces go back together.
Posted on Dec 10, 2008
Ek7301 Makita set carburetor mixture screws? It will not pop or start ? Changed fuel,removed plug it has spark , replaced plug, still no pop?
screw the mixing screws in and back off half a turn. then try again, when started adjust the screws to best suit you need. only half turn each time.
Apr 21, 2018 | Makita Garden
How do you get to the inside of a makita 4.5"
there is a screw in the bottom of grinder next to the power cord, that's all you have to take.
(althought I don't know the model of your grinder, the most of makita brands have the screw right there) good luck!
Jul 02, 2011 | Makita Saws
I need help to replace my brushes on a makita 9553NB 4 inch angle grinder the old model i used to have had easy access.. coin sized slots on the handle that you simply uncsrew to reveal the brushes. my...
first unplug the tool, next on the backside you will notice a screw, remove it and slide the cover back to expose the backside of the motor. gently move the springs that hold the brushes tight to the side and remove the brushes and replace. Make sure to replace the springs and then slide the cover back into place and replace the screw and that should take care of your problem.
Feb 18, 2011 | Makita 9553NB 4" Angle Grinder
Hi, my BO5010 spins like a grinder if it is not held tightly to the workpiece, can it be fixed? Thanks, Ope.
Just under the sandpaper pad is a bearing that allows the pad to work as an orbital, that is it can turn freely, independently of the armature. If enough sawdust builds up around or inside this bearing the pad will spin like you describe and this is a fairly common problem with orbital sanders. You need Makita part number 211236-8 or a bearing #6002LL. It's fairly easy to replace; remove the screw in the center of the pad and remove it. Depending on which is tighter, the bearing will either be in the back of the pad or it will stay on the armature. Pry it off/out of the sander. Reassemble everything with the new bearing and you'll be back in business.
Dec 30, 2010 | Makita BO5010 5" Random Orbit Sander
How do I replace the power cord for a makita palm sander? Specifically once all the visible screws are removed how does one separate the two body havles?
without knowing what the model number is you also have to remove the pad assembly and usually you will find some there if all removed you can GENTLY pry the cover halves apart. Go to Makitatools.com with you model number and you can download a breakdown for this tool.
Mar 14, 2010 | Makita Tools & Hardware - Others
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
Pad siezes up
Use some loctite thread locker on them.
Jan 17, 2010 | Makita BO5010 5" Random Orbit Sander
Can't remove the chuck retaining screw.
The screw is a LEFT HAND THREAD and also is LIKELY a Metric size!
Make sure you use a Metric Allen wrench.
Jul 08, 2009 | Makita 6408K 3/8" Variable Speed,...
Makita random orbit 5". The pad flew apart. Is it replaceable ?
Usually there are 3 screws holding the plate to the eccentric assembly. The pad is formed to a metal plate and is sold as an assembly. You can go to Makitausa.com with the model number and get a replacement pad.
Feb 07, 2009 | Makita 5" Random Orbit Sander
Makita BO5010 5" Random Orbit Sander Logo
197 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
