Question about Dell Dimension 2400 PC Desktop
Cant connect to the internet
I have a dell dimension 2400. i kill disked the computer and erased everything, tunrs out the harddrive was shot. i replaced the hard drive, re installed operating system windows xp, and now i cannot connect to the internet. i have brighthouse road runner with a cable modem. i found in another answer to go to my computer, properties, hardware, device manager, and saw the ethernet controller, multimedia audio controller, and video controller (VGA compatable) has a question mark next to it. i tried the installation cds and cant find the drivers. i can connect to down load the drivers. i am writing this on another computer....HELP!!!!
THANKS
  • 2 more comments
  • rukycop Dec 10, 2008
    i found the site...thanks alot...but how do i get them from this computer to the one its needed on. can these be burned to a cd? then installed on the other computer? thanks again
    frank
    usb stick...moron...i didnt even think of using that. i will try that once i find the right driver. thanks for the info again. last question about this...i could not find the ethernet controller, multimedia audio controller, and video controller (VGA compatable) drivers in those lists ya'll sent. i will look again, could they be under a different heading or area.
    you guys have been great, and i really apprec the help. i am not too computer literate and am thankful for this site.
    frank
    hey i did it!!!!. thanks again for everyone's help. this is an awesome site.
    thanks
    frank
  • Anonymous Jan 05, 2009
    What Web Sight To Go On To Download The Ethernet Controller Driver For The DELL Demension 2400?
  • 117 Answers
Sounds like you reinstalled your windows, but didn't install drivers? Here you can download network and other missing drivers for your dell model http://support.euro.dell.com/support/downloads
Posted on Dec 09, 2008
  • Illimar Saatvali
    Illimar Saatvali Dec 10, 2008
    Easiest way is to coy on memory stick by usb
    President:
  • 1,073 Answers
  • Nicolas
    Nicolas Dec 10, 2008
    Yes u can burn them on cd, or store them on a usb-stick
    Good luck
  • Nicolas
    NP:)
    Glad to help you!
Where is harddrive located in 2400 series
here is the detailed instructions for locating removing or replacing hdd from your computer https://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm
Jan 23, 2012 | Dell Dimension 2400 PC Desktop
Cant get on the internet
The longer the cable, the slower the connection.
It should work with the cable as it is not "too" long.
I would try turning the modem and router off for one minute and then turning back on.
Jennifer
Dec 29, 2009 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 and want to reload operating system , dump every thing and start over. I re load the windows OS disk but didn't dump all the old files and programs .I have several disks that...
Hi:
Basically, you need to do four steps:
1) Run the Windows OS installation
2) Install all drivers off of the driver CD
3)Install programs and software that came with the computer, or ones that you added .
4) Connect to the internet, and validate your copy of windows, and run Windows Update again and again, until there are no more updates to download.
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
I can't connect my dell dimension 2400 pc dt to the internet, it says that it is reading the connection but it won't connect
Check it in the Device MGR see if it is working ok then update driver or completely uninstall it and Restart and it will find and reinstall it ! If you have the dell disk put the driver disk in and reinstall it from disk. Hope this helps!
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
I cant get my dell dimension 2400 to detect my modem to access dial up internet it has windows service pack 3 (xp) please help
try this driver:
http://www.findmysoft.com/drivers/download-Dell-Dimension-2400-Intel-modem-driver.html
Oct 27, 2009 | Dell Dimension 2400 PC Desktop
I have a Dell Dimension 2400 with windows xp. I was having some problems and decided to reinstall xp. After the install, my resolution was set at 480 x 640, everything was big on the screen so I went into...
install windows xp after that open link and download driver and install driver and enjoy .....
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P4_CEL_2400
Oct 14, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
I turn the computer on and all I get is strike F1 or F2 to setup utility. But, cannot fix it . I just replaced the harddrive in October or November 2008.
Run the setup and check if your PC detect the hard drive. Check also the IDE/Sata connected from your mainboard to hard disk.
Jun 08, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
543 people viewed this question
Alun Cox
