Question about Umax PowerLook 2100XL Flatbed Scanner
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED AND WAS WORKING FINE. NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
  • 3 more comments
  • gcastro Jan 12, 2009
    I have the same exact problem! Please help!
  • shrikrish331 Feb 05, 2009
    I am using umx scanner 2100 scanner led's working ok it;s on also I am using adaptec scsi card.SCSI card shown in device manager but if i am going to take scanner test at that time scanner test failed please give me solution how can i solve this issue.
  • scorpio 6 Mar 05, 2009
    Same problem, Scanner working fine then will not go through start up
    procedure, both lights are flashing 3 times then off and seconds later
    flashes 3 times again and again.
    Have checked all moving parts inside for obvious problems but cannot see any.
    crinstone@postmaster.co.uk
  • Cleverer2 May 11, 2010
    Is the transport or carriage LOCK engaged? Look on back and underneath for this
    (an office clown may have flipped it)
    Does it make noise, Grrrrrrrrrr, or does the tube light and move out and back on power up?
  • Anonymous Oct 15, 2016
    Please open Our memek
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Posted on Mar 20, 2010
Wore my Umax Scaner 2100 xlmy problem. power and ready light is blinking
Posted on Nov 24, 2009
If you are using Windows XP, You must power up the scanner before switching your computer on. This is essential !!!!!
Posted on Mar 05, 2009
  • Teresa Wong
    Teresa Wong Jan 13, 2014
    I did turn on the scanner first. But once I turn on, the light will be blinking.
I have an UMAX Powerlook 2100XL. My OS is windows 7. I do not have slot for the SCSI. Is there any way to use this scanner with a USB connections
there are some Firewire to SCSI and USB to SCSI adapters that should work- check www.hamrick.com. Ed Hamrick has written Vuescan scanning software that will work with the 2100XL, windows 7 and many of these adpters
Oct 13, 2010 | Umax PowerLook 2100XL Flatbed Scanner
CAN NOT GET IT TO RUN AGAIN> UMAX 2100XL SCANNER
http://www.umax.com/download/index.jsp
Please go to the link, select the model and your operating system
Alternatively, you could use the CD that came with the scanner.
There are two things, a driver and a software. From the CD or above link you can get both. But, you can even use a separate driver and software to get your scanner running.
Please drop a comment. Thank you!
Jun 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
Umax PowerLook 2100XL Flatbed Scanner won't power up
the light may have gone, change the buls, also have you got your installation cd you may need that just in case it is not found you have to reinstall
Jan 12, 2009 | Umax PowerLook 2100XL Flatbed Scanner
UMAX Scanner
I found the drivers on the UMAX site: ftp://67.66.169.205/scanners/magicscan/version4.5/mscan45.exe, http://www.umax.com/download/index.jsp. I just don't know how to connect it... :S
Nov 13, 2008 | Umax PowerLook 2100XL Flatbed Scanner
How tha scanner instaled?
hi,
1. connect the scanner usb cable to your desk top
2. install your scanner driver (cd of your scanner) to your computer.
3 as you put the cd in your desk top computer it will give you guide line (just follow it)
thank you....
Nov 11, 2008 | Umax PowerLook 2100XL Flatbed Scanner
Umax PowerLook 2100XL - Driver
Go to
this download page on the UMAX site
and select your device (Scanner), then your scanner model (Powerlook 2100XL) , and your operating system, then press the "SEARCH" key.
Each page in the Download Area is in two languages - first German, then English, so page down to the English section.
Follow the instructions to download the correct driver for your scanner / operating system combination.
Note there is currently no driver available for Windows Vista.
When you've tried this solution, don't forget to rate it !
Good Luck.
Apr 28, 2008 | Umax PowerLook 2100XL PrePress Flatbed...
Umax PowerLook 2100XL Flatbed Scanner Logo
1,763 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
