Question about Comfort Zone CZ-441 Ceramic Heater
No power heater is less than a year old, when you plug it in no power. what's wrong?
    Genius:
  • 1,199 Answers
Look for a fuse!
Posted on Dec 09, 2008
I have a paloma ptg2-42pvn tank less water heater. I recently installed the remote as the unit quit making hot water. I wanted to see if it was producing a code. The remote is flashing 76 repeatedly. I...
Bad remote control. Bad wire to remote control. Bad PC board.
Copy following link for resources, including older service manual and error codes and rheem chat for ordering replacement motherboard for your tankless computer.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If tankless computer is 5 years old, then compare that to your 5-year old cell phone or 5-year old laptop, and ask if the chipware still functions or can be repaired to function back to factory fresh expectation.
Later today, install tank type water heater and solve all tankless computer problems with one ez step. Have hot water for shower same day with less maintenance and fewer long-term problems and expense.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 24, 2013 | Water Heaters
3 tv' s in my home stopped powering on on the same day. I have a 46" and 60" plasma' both less than a year old and a 27" LED. I checked the breakers. I unplugged and plugged them in again. Al
Your tvs sensitive ic chips on the power boards have been subjected to an undetected voltage spike and are fried. I'm guessing that none were plugged in to a surge protector?
Apr 20, 2013 | Panasonic VIERA Televison & Video
Heater less than 1 year old. Worked fine 3 days ago; tried turning on tonight and got a "E01" in display. Anyone know what that might mean?
E01 is low system voltage. This can be caused by 3 things. Either the incoming power is incorrect, the heater is connected to wrong voltage, or the tranformer is not outputting the correct voltage.
Check voltages going into the heater, if these are all correct, then replace the transformer
Feb 06, 2011 | Pentair Minimax NT Heater
Need an electrical diagram for an empire WFA 35s wall heater. It is at least 30 years old. Thanks
Unfortunately, Empire Comfort Systems hasn't made that wall heater in years. Never the less, you may get lucky by calling Empire direct @ 800-851-3153 and ask for Technical Service. Maybe one of the old timers can help you out.
Jan 16, 2011 | Empire Heating & Cooling
The heater is less than two years old and it blows cold air, and not heat!
Make sure with a multimeter that the heater is having the continuity and the switch is contacting correctly . If so the heater must work.
If not the coil can be faulty or the switch can be defective.
Sep 28, 2010 | Lasko 5520 Ceramic Compact Heater
How old is my Rinnai Convector 516 TR?
2000 is the year of manufacture
Nov 09, 2009 | Heating & Cooling
Samsung less than year old, sound but black screen
lizau2011, This is probably a premature failure in one of the power supplies inside the unit. If unit is under warranty you need to contact the Samsung people to get it repaired. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Sep 23, 2009 | Samsung HP-T5044 50 in. Plasma TV
FV sensor went out when ainting the basement floor. The fumes burned out the sensor, purchased a new sensor, went to install and nothing happens. AO Smith water heater pro/Max
I find that most times when people think something is wrong and "FIX" it "BUT" it doesn't help, that just wasn't the correct diagnosis.
You may do better to look inside your info. that came with your W/H or call the company directly.
You didn't say how old it is. In some cases if the W/H is less than 1 year old they will repair it at no cost.
Hope This Helps;
JSTACH
Sep 06, 2009 | Heating & Cooling
Having a problem with a heater i bought
I have the same heater and when that happens just unplug it for about 15 minutes and plug it back in and it should work fine. It only does this for me when I am using a extension cord or a power strip. It needs a dedicated power supply (wall outlet) with nothing else attached. If you must use a extension cord I have found that the heavy gauge orange power cord is the only one that does not overheat and causes the heater to shut off. The heater comes with a 3 year warranty, the longest warranty I have ever seen with a heater.
Mar 25, 2008 | R.A.M. Computers LASCO-5540 Ceramic...
Comfort Zone CZ-441 Ceramic Heater Logo
124 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
