Question about Kitchen Ranges
I have a Blaze King Wood Stove (approx. 20-25 yr old) that will not stay lit. Problem started yesterday - have been burning it without problem for last 2 months. Damper control was open as much or more than in the past. Any ideas what the problem might be?
  • Anonymous Jan 10, 2009
    same problem, damper doesnt seem to have any effect on hte fire.
  • 1314 Answers
SOURCE: stove top burner replacement
if your sure you have it wired correctly then replace the switch but first id double check the wiring on the switch
Posted on Jan 10, 2008
techman
  • 3130 Answers
SOURCE: I have a Technika DAB-206
You have leaky filter capacitors in this radio, this is a common fault and these are soldered into a rinted circuit board. Good luck
Posted on May 29, 2008
micromaster
  • 3614 Answers
SOURCE: The oven pilot to our
have you done testing and checking the unit, it seems that your problem was on the thermal fuse, and this part need to be replaced if you find it burned or busted
Posted on Aug 07, 2008
  • 48 Answers
SOURCE: burned on stain on burner will not come clean using cleaner and the blade
There are some very effective commercial products available. One of the most highly rated is Cerama-Bryte, but BE SURE TO FOLLOW THE DIRECTIONS CAREFULLY....as once it dries it is impossible to remove!!!!! Work in small areas, rub consistently.
As well, mr. clean magic eraser also has worked magic on my mothers stove over the past few years also.
If you wish to stay away from the store-bought chemical....soaking the spots with water and ammonia OR vinegar..(not both) and elbow grease. As well....the razor blade in combo with the liquid.
Be sure to rank me.....please....especially if this Fix-ya`s....
Posted on Nov 07, 2008
SOURCE: Amana Mod # ABB2223DEB Refrigerator
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
Posted on Dec 03, 2008
How to put the mantel and flue parts back on in the fireplace
Fireplace and Chimney Parts: Diagram and Anatomy
https://www.highschimney.com/.../parts-chimney-anatomy-fireplace-chi...
Nov 30, 2011 - A chimney is made up of up to 22 parts. ... Mantle - Also known asmantel piece or mantel shelf, this piece of hardware is more than a .... I have an old Blaze King Fireplace Insert that was purchased back in the mid 1980's.
How to install a wood burning fireplace insert - Hearth.com
www.hearth.com/econtent/index.php/articles/install_insert
A Heatform is a metal firebox which is built into a full masonry chimney. ... The distance to the adjacent wood trim and the mantle. ... All the way back in the fireplace, or out on the hearth? ... Rockford Chimney Supply - We are the best source forChimney liners and Stainless steel chimney liner kits to install your insert or ...
Dec 20, 2015 | Heating & Cooling
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
Smoke comes out of draft vent and everywhere when starting a fire
Ugh, my husband does this... You have to start the fire so that it does burn hot enough to force the smoke up the chimney (and, yes, make sure the chimney valve is open!). To do this, keep building the fire in baby steps: light with balled up paper beneath a "teepee" of kindling and keep the door open. Once enough kindling is burning, add a couple pieces of larger wood (make sure all is very dry, especially to start) and start closing the door, but make sure the vent is open all the way. Once the wood is burning, add a couple more larger pieces and begin closing the vent - a little at a time, checking every few minutes. No, you don't have to stare at it the whole time, but keep checking. After awhile, you can fill the stove with very large pieces of wood and have the vent closed far enough to lower the flames to very small - but not to smothering totally. This is where the heat really starts and your room gets warm!
Mar 06, 2015 | Home
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
Auger not working on Blaze King Pellet Stove
depending on how the manufacturer set up the system, there may be pellets wedging the auger. most augers are geared low enough to snap the pellet but if its something else blocking it (stick or rock etc) it may have blown a fuse for the auger drive or the drive mechanism itself. if you are going to work on the auger. UNPLUG THE STOVE AND USE TOOLS TO CLEAR BLOCKAGE as there may still be some pressure to spin auger
Aug 07, 2017 | Pool & Spa
Our LP Buck Stove will suddenly not lite. The pilot is lit. To start the stove, we just push the ON button and the fire lights, it stopped lighting without warning yesterday. Any ideas what is wrong? I...
If I understand it correctly, the pilot light will light and burn, but when you turn the Control Knob to the ON position either the burner won't light? My question is, doe the pilot stay lit or does it go out, when you do this.Also, is this a Vented or Vent-free Gas log Stove?
If it's vent-free, the Oxygen Depletion Sensor (ODS) which is part of the Pilot needs cleaning. As, it may be clogged with dust, lint & pet hair and it's sensing that there is not enough oxygen for safe combustion. The other issue tis relative to the pilot assembly, is whether this unit has a millivolt control valve and the Thermopile has failed. The Thermopile controls the opening and closing of the gas valve when you turn the Control Knob or ON/OFF switch to the ON position.
If it's a Vented unit, the same thing applies to the Thermopile.
It would also be wise to check the amount of gas you have in your tank. It may be to low to sustain combustion of the burner(s), but has just enough to keep the pilot burning.
Hope this helps you to Troubleshoot the problem. If it does please leave me a positive approval.
Thanks!
Mar 26, 2011 | Heating & Cooling
I'm looking for a manual for the Amaza Blaze corn stove, or help in finding out why it won't stay lit.
Get it from:
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Dec 16, 2010 | Heating & Cooling
How can I re-enamel an old wood burning stove?
For my outdoor burner i use Krylon high temp flat black which works great for me, Sherwin-Williams has a large variety of high temp paint for your application.
Oct 10, 2009 | Ovens
When we lite up the wood burning stove the smell and the fumes are really strong the fires has been lit about 6 times any help?
the chimney pipe most be the same sides all the way out , it can not begin big and then small as it goes out. that's the problem with, your wood burning stove. it can be small and then big but not the other way around.
Dec 07, 2008 | Kitchen Ranges
Kitchen Ranges Logo
204 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
