Question about HP LaserJet 1600 Printer
Printer doesn't reset after refil
I have refilled the black cartidge on my HP laserjet 1600 using a refill starter pack ..essentially burning a hole, refilling and plugging and trimming as instructions - when reinserting the cartidge the printer still sees the cartidge as empty - has anyone solved this before ? I have tried reinserting and rebooting but no luck still
You can change the setting in the printer through the LCD display so that it will not check the level of the cartridge by placing it in override. You will have to note when it runs out of toner as the pages become streaked or faint as you are now running in manual.
Posted on Aug 24, 2009
    New Friend:
  • 37 Answers
I don't know what this "refill starter pack" contains but you HAVE TO change the chip of the cartridge otherwise the printer does not know that you changed/refilled the cartridge.
Posted on Jun 23, 2009
Problem hp pro 300 don't copy black
Check your black cartidge even if it's new. Take it to a refill site,
they may unstuck it using utrasound
Oct 24, 2015 | HP LaserJet Pro 300 Color MFP M375NW...
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
How to toner refeil
r u a professional??
if so pull out the toner cartridge, unscrew from both side, gently remove the drum & the magnetic mesh roller, be careful that the teflon cover is not affected n there is spring on one side, clean the drum with a soft cotton cloth n keep aside, now clean neatly the container vessel & magnetic-mesh roller using a brush, refill using 'original' refill pack, don't refill till brim, reassemble all, after reassembly, clean all toner spills using soft cotton cloth, blow some heat on the drum using a hair dryer..itz ready
..always hv an expert supervision n always use genuine spare n refills..dis will make ur pc last long....
Oct 28, 2009 | HP LaserJet 1600 Printer
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
Jul 30, 2008 | HP Office Equipment & Supplies
Refilling
You will have to do a melt and pour to replace the toner.
Go to page 70 on this link:
http://www.uni-kit.com/pdf/tonerrefillinstructions.pdf
Jun 20, 2008 | HP LaserJet 1600 Printer
Refilling of Laserjet Cartridge
dear sir good morning
sir please send a soulation for refilling of hp laserjet 1020 prineter cartridge with graphic soluation. request send immeditely in my E-Mail ID
shaan_rao@rediffmail.com
May 15, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
HP LaserJet 1600 Printer Logo
285 people viewed this question
Seeker5211
Seeker5211
