Home | Nikon | D300 Body Only Digital Camera | Nikon D300 Nothing in ...
Nikon D300 Body Only Digital Camera
Problem for Nikon D300 Body Only Digital Camera
Nikon D300 Nothing in Viewfinder or Control Panel
By amber_crabtr on Dec 09, 2008
My camera is only 6 weeks old and I've been having this problem for about 4 weeks. The camera is off and it looks as though the battery is dead except for there is nothing in the control panel denoting the need for changing the battery. Then when the camera is "on", still nothing is in the control panel and when I look through the viewfinder all that is shown is a fuzzy grid. This grid appears with a lens attached and also w/o a lens. Sometimes if I take the battery out and put it back in, the camera will switch on and look as if there is no problem at all. But sometimes it needs a charge, but generally it is a fully charged battery. I have never had to recharge my battery because the blinking at me. It is only because of this weird problem.
Same Problem
Apr 04, 2009
-   I have just got back from holiday and was hoping to upload the pictures from both memory cards on to my laptop.  In the process of switching the cards over to complete this process, the control panel on the D300 went completely blank in both 'On' and 'Off' mode and looking through the viewfinder reveals a fuzzy screen with a few oddly scattered boxes.  I am unable to switch the menu on either.  I have only had the camera 8 months and have probably taken about 1500 shots with it.-   TekPhobe
Dec 29, 2008
-   I also have viewfinder problem first time I used my D300 for a photoshoot yesterday. The problem I have is that the viewfinder shows two grids and two center focus indicator. Pictures taken were fine. Looks like there is a major electronic flaw in the viewfinder circuit. -   frankie458
Dec 19, 2008
-   The control panel on my D300 suddenly went blank, as did the display that is inside the viewfinder, along the bottom of the screen. Changing out the battery with a fully-charged one did not correct the problem. The camera still functions, and takes good photos, but no data is shown in the control panel or inside the viewfinder. The menu can be read on the LCD screen on the camera back, but not on the control panel. My camera is about nine months old, and has only taken a grand total of 800 photos. Everything worked well until this problem suddenly happened. Any solution would be much appreciated, although I think I'm going to have to send it in for repairs.-   troutbum24
Popular Solutions for Nikon D300 Body Only Digital
Questions and Unsolved Problems for Nikon D300 Body Only Digital
Do you recommend Nikon D300 Body Only Digital Camera?
Answer
Answer
out of warranty Nikon D300 with a continuous blinking "ERR" message. Tried multiple... (More)
Answer
D300 says "no images in folder" but I can download the images easily using a card reader.... (More)
Answer
compact flash slot damaged, one of the pins is bent and I cannot fix it
Answer
I have a Nikon D300 that will not turn on at all. I have checked the battery and it is fully charged... (More)
Answer
d300 does not accept cards, gives CHR message tried several Sandisk & Lexar cards. used it... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D300 Body Only Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
