I am unable to lower or raise the hook due to the tangled string inside. How do I pull it apart?
WOO HOO I FIGURED IT OUT!!!! You have to pull it apart from the base up. First thing I did was take off the feet. If you look down the tower potion you can see a screw. Then u took off the tower. I figured out that if you just lined up the black square portion it would have come apart with just the one screw. Anyways now there is 2 more screws to get. 3 total to take the new bright tc36 tower crane apart. They are hard to see, but once the base is off you can get at em. Good luck everyone.
SOURCE: can't figure out how to put on new string after i took off the old string
I figured it out. Went on YouTube and watched a couple videos and did it myself. Thanks!
SOURCE: can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
SOURCE: Pull String Ripped out, How to Replace?
no its not imposssible.but its not easy unless u have done a few times.you have screws around the plasic casing get them out.and pull
shaft off engine.
SOURCE: I need to put in new string -- don't know how to
This trimmer is an "AFS" (Automatic Feed System) trimmer meaning the trimmer uses centrifugal force and a lever that play out trimmer line without you ahving to bump it on the ground. Your trimmer uses .080" diamter line. You can get a replacement spool and lever at Lowe's fairly cheap. I would say get the spool that is already wound rather than trying to buy just the line and re-spooling...that will make this a LOT easier!
What you do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head of the trimmer and follow the steps below:
1. Remove the spool cover (this is the orange cap on the head)
2. Remove the spool, (observe and note the orientation of the spool!)
3. Using a pair of pliers, pull the orange feed lever straight out (observe and note the orientation of the lever!)...do not try to pry it off, you will damage the head!
4. Insert the new lever in the same orientation you noted when you removed the old one.
5. Insert the new spool and line in the same orientation as the old spool.
6. Replace the cap.
Black and Decker has an 800 number you can call if you get stuck, the number is 1-800-544-6986. Good Luck!
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
