Question about Intermatic OUTDOOR DIGITAL TIMER
I DO NOT KNOW HOW TO SET THIS TIMER. I DO NOT HAVE INSTRUCTIONS.
  • 33 Answers
I don't know what timer you have but if the one you have matches the photo here is the instructions link:
Intermatic HB88RC
If you want to check out and find out what model number it is check here when you know:
Intermatic manuals
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
Do not know how to open door of the intermatic wall time switch Do not know howto set timer--I want timer to go on at 7 PM and turn off at 7 AM
Question posted under ET104 timer.
This timer arrives with default voltage set for 240Volts.
Move voltage selector to select 120Volts as per instruction manual:
http://waterheatertimer.org/pdf/Intermatic-et104c.pdf
You can add a comment any time for more specific help with this timer.
1) If this is a plastic enclosure, then push inward to unlatch enclosure door.
See illustration: http://waterheatertimer.org/images/IMG_9431-Open-enclosure-400.jpg
2) Model number of timer and wiring diagram and programming appear on inside of timer door.
Add a comment with timer number if different from below.
3) How to program ET104 timer:
http://waterheatertimer.org/pdf/How-to-program-Intermatic-ET104-timer.pdf
-Read instructions.
-Set current time.
-Set program 1 for 7pm
-Set program 2 for 7am
-Not necessary to use programs 3 4 5 6 7 8
4) More resources
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET100
Sep 22, 2011 | Intermatic INC ET104CPD82 24 HOUR...
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Open following link for instructions how to set analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Sep 02, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
Hi how do i set the the 59200 timer for indoor use. does it matter if you use the nos on the white side of the dark side of the timer? im not following the instructions. how do u know how many pins to...
Each pin/segment represents 30 minutes.
To set timer for 2 hours, move 4 consecutive pins/segments up or down.
For 8 hours, move 16 consecutive pins/segments
http://waterheatertimer.org/images/Raise-segments-240.jpg
Dark background for numbers are usually 'night' or 6pm to 6am.
Timers usually have am and pm printed on timer dial.
Open following link for analog timer instructions:
Jul 18, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Intermatic OUTDOOR DIGITAL TIMER Logo
184 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
