Question about ASUS EXTERNAL USB FLOPPY DRIVE (ASUUSBFDD) Media
The system tray icon, for USB device inserted, keeps falshing, and immediately goes off, even when there is no USB device inserted.
How do i use the wifi?
You will need a wifi adapter (usually a small USB device that must simply be inserted) and you will need to install the appropriate drivers for your wifi adapter. Then you will need to reboot the PC.
Once that is done, or if your manufacturer has done that for you, you should see a small icon near your system tray, near the clock (you may need to expand the tray by clicking the arrow). The icon should be a series of growing horizontal waves. Click the icon and select the "Select Network" option from the menu. You should then be able to select your wireless network by clicking on it and entering any WEP Key (password) that is neccessary. Your WEP Key should be printed on the side of your router.
Apr 07, 2011 | Computers & Internet
Cant get the pulsar 590 works with windows 7
I finally solved this problem. Buy a CSR v4.0 enabled bluetooth dongle on ebay, plug it in to a usb slot. Right click the bluetooth icon in system tray and select "Settings" and tick "Allow bluetooth devices to find this computer." Then click "add a device", turn on your bluetooth headphones and the headphones will show up in bluetooth devices. Add the device, then right click your speaker icon in the system tray, select playback devices. From the menu, select the headphones and set them as default. I did this and they work perfectly. Furthermore when I turn the headphones off, the sound goes back to normal speakers - no other adjustments made. Turn the headphones on again and the sound defaults to them. I noticed on an earlier failed install of the headphones when they did appear in Devices and Printers that the drivers were CSR something enabled. I did try some cheaper dongles and the actual Plantronics USB dongle(expensive) to no avail. Get a CSR 4.0 enabled device. Mine cost 6.00AU total.a199a342-df05-4c7a-89f7-c82a948f31c9.jpg
Feb 21, 2011 | Plantronics Pulsar 590A Wireless Headset
How to formet transcend usb flash drive.
Insert the flash drive into the usb port of the computer .Once you plugged the device it will be automatically recognised by the operating system .In case of windows operating system you find a new icon in My computer.On the icon of the usb device right click it and there will a option to format it.
Jun 17, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Whenever I plug the USB cable into my camera, the screen goes black. It does it even when the cable isn't plugged into the computer. Even though the screen is black the camera still functions normally but...
As far as I know, most cameras are made so that once it senses a USB cable (whether as being inserted physically or as a source of current), it reduces the camera to pretty much no more than a memory card reader.  It is my belief this is so you can't use your camera directly with your computer, either as a web cam or using your computer as an immediate storage device.
Oct 22, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
It won't hotsync, it start to than stops when I get to the what should I do I have a tx
Here are a few things to try:
Check that the HotSync icon in showing in the system tray (bottom right hand side of the screen, next to the time).
Check that USB connections are enabled in HotSync - In HotSync V7.0.2, Right click the hotsync icon in the system tray, Click "Settings...". Click "Connections" on the menu on the left hand side and ensure that the USB option is checked.
Try rebooting your PC and also resetting the device (use a paper clip to reset the device).
You could also try reinstalling Palm Desktop, maybe even remove Palm Desktop, reboot, then reinstall Palm Desktop.
Jul 31, 2009 | Palm Computers & Internet
Optical Drive Device Locked Acer e lock activated. I cannot use my Cd drive.
Acer eLock Management
Acer eLock Management is a security utility that allows you to lock your removable data, optical and floppy
drives to ensure that data cannot be stolen while your notebook is unattended.
Removable data devices - includes USB disk drives, USB pen drives, USB flash drives, USB MP3 drives,
USB memory card readers, IEEE 1394 disk drives and any other removable disk drives that can be
mounted as a file system when plugged into the system.
Optical drive devices - includes any kind of CD-ROM or DVD-ROM drives.
�� Floppy disk drives - 3.5-inch disks only.
�� Interfaces - includes serial ports, parallel port, infrared (IR), and Bluetooth.
To activate Acer eLock Management, a password must be set first. Once set, you can apply locks to any of the
devices. Lock(s) will immediately be set without any reboot necessary, and will remain locked after rebooting,
until unlocked.
You can try this:
You can reset the system to its default settings (all devices unlocked) by removing the password (leave the password fields blank when changing the password).
You also may be able to simply uninstall the e-lock software in add remove programs.
Is there an icon in your system tray that may allow you to disable e-lock?
Dec 30, 2008 | Computers & Internet
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
RCA RP5022B Digital Voice
on XP try the "<" circle on the system tray and look for the USB device manager, disconnect from there.
If it is not there, or older systems try Start, Control Panel, System icon, Hardware Tab, Device Manager button. Find the Universal Serial Bus controllers, right click on the Device and select disable in the floating menu. that should allow you to remove the device safley.
Feb 16, 2008 | Audio Players & Recorders
PC shows no disc in drive E
is this because i used the usb cable for another devide?
- i dont think so. the usb cable that comes with the benQ camera is the usual usb cable. i used it for other devices and still works fine with my camera again. i even used another usb cable from other devices in camera and it works fine.
is it a virus maybe?
- well you can try inserting a different device in that usb port, now if it still cant see it, its probably busted. all your usb ports are on used? wow! how about you try taking some of it out and check those ports for your camera.
Nov 26, 2007 | BenQ DC3410 Digital Camera
Electronics - Others Logo
21 people viewed this question
Top ASUS Electronics - Others Experts
Cleverer2
Jax Planet
Jax Planet
andrewcahoon
Are you an ASUS Electronics - Other Expert? Answer questions, earn points and help others
