Question about Energry Speakers Energy Speakers S8.3 Subwoofer
No power going to Energy s8.3 subs GRR!
Just purchased a set of Energy S8.3 subs and one of them works.. had some dude from future shop set them up, they both worked for about a week, had to get new carpet laid in my livingroom so everything got unplugged and got same guy to re-do alll the electrical ****.. nooow only one works.. tried differnet outlets, still nothinng.. helllp mmeee!!
  • kactghn Dec 09, 2008
    under the circumstance that there is no visible fuse plug anywhere on the outside woofer, what would be another option?
    annnd thnx :)
  • 492 Answers
Usually there is a fuse plug next to the power input. Check to see that the fuse is not blown. If it isnt call the guy, he is legally responsible for any work he performs.
Posted on Dec 09, 2008
What sources of power do you think will be used in the future?
In my opinion, the use of fossil fuel sources of energy will decrease in the near future. Meanwhile, other forms of clean energy will be cheaper and more available, like: solar, wind and hydroelectric energy.
Jan 04, 2017 | Green Living
The on off button on front doesn't turn the unit on and off. The light is always green (never orange). The display doesn't work either connected to PC with with D-sub or DVI-D. Is hw damaged?
Go to CMOS setting on your computer motherboard and check energy saving settings. Also check if your PC, motherboard, and OS are compatible with EnergyStar Power savings.
Aug 24, 2015 | BenQ FP951 (Blue, Gray) 19" LCD Monitor
Schematic
i have same isue humming like hell ,change 2 power supply capasitor didnt do it ,try to changer 2 mosfest transistor Samsung IRF640 N-channel MOSFET TO-220 200V 18A hope it will do it ,on ebay for a 2.00 each .
i think it is power supply isue ,recterfile circuit not clean it will give you that 60hz humming noise ,good luck
will let you know how it turn out ..
Jul 14, 2013 | Mirage OMNI S8 Speaker
Green and red screen on Samsung SyncMaster 920nw
Replace the video cable or hdmi,depending on which you may be using. Some of the small wires in that cable may have snapped. Another suggestion is to take it into a repair shop that gives free examinations or diagnosis, because one of the small leads going from the screen to circuit boards lining the display, may have broke, unfortunatelly this may lead to you having to buy a new display. Most of the time it can not be reconnected due to many wires in the same ribbon are to close. You may also have to purchase a new screen from the factory.
Feb 07, 2013 | Samsung SyncMaster 920NW Monitor
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
I have a Mirage Prestige S8 subwoofer. 4 years old. Suddenly nothing....not functioning. No change in usage or location. Any ideas?
Check the status indicator - The LED found on the front panel should be illuminate in blue when the subwoofer is functioning. If the unit is in Auto mode and is not receiving a signal, the light will remain off. Try setting the power switch on the back to ON if in the Auto setting. Post back the status of your LED.
Aug 31, 2011 | Mirage Prestige S8 Subwoofer Speaker
Yea, mines cant charge either
well sorry dude but is prob broken, the battery mabye is dead somehow. go ask some future shop people how to fix, im not so sure on this one.
good luck!
Jul 15, 2009 | Apple iPod touch
Jvc th-s8 no sound
There is a stock fault on the sub woofer unit.
R2702 fusible resistor is likely to be faulty.
Here is their modification - dodgy english but you get the idea.
Reasons: R2702 (QRZ9005-470X) a 47 Ohm 1/4W resistor is open circuit due to rush current at the time of
power supply ON/OFF.
Cure: 1) R2702 change value : QRZ9005-470X --> QRJ146J-220X
2) C2704 change value QETN1EM-107Z --> QETN1HM-476Z
Sep 28, 2008 | JVC TH-S8 System
Celestion S8 Subwoofer
I would check the electroltyc caps in the power supply They general are in the first part of the power supply and there will be two of them . What they do is filter out transformer hum and help stabalize the circuit. I am not saying this is absolutely the problem but the capcitors are relatively inexpensive, Easy to change. And have a habit of going bad after a couple of years in use.
Aug 22, 2006 | Celestion S8 Subwoofer
Energry Speakers Energy Speakers S8.3 Subwoofer Logo
433 people viewed this question
Top Energry Speakers Audio Players & Recorders Experts
Rob
Rob
Michael Edwards
Michael Edwards
Level 1 Expert
Tom Chichester
Are you an Energry Speakers Audio Player and Recorder Expert? Answer questions, earn points and help others
